russian wrote:
x3 MCP42010-I/SL-ND
x2 10x2 pin headers (black on the sketch)
xX 5.08 screw-in terminals (red on the sketch)
There are few things I want to clarify.
1. Russian, is there a reason you choose the 10x2 header at those positions?
2. I don't see VCC on the header. Do you intend to power this externally?
3. Do you intend to use the USB on the STM32? I assumed you do.
4. Do you plan to use a logic analyzer to scope the outputs? I want to create a header so we can use something like the OLS (Open Logic Sniffer). That way we can control both the stimulator and the the capture mode and triggers all via USB.
Stimulator features I have in mind:
* Uses the discovery board as the controller
* 6x 10k digipot via 3x MCP42010-I/SL-ND
* 18 pins header for logic analyzer, 16 signals, 2 GND, designed for OLS (Open Logic Sniffer)
* 2x VR/Hall outputs, routes to OLS
* 4x configurable Highside/lowside/CMOS outputs, routes to OLS; 1 or more of these output can be used to trigger OLS
* 10x configurable Pullup/pulldown input buffers, routes to STM32 and OLS
The way this stimulator will be used is the STM32 will generate the VR/Hall wheel ouputs, control the digipots, and set the trigger for OLS. Then the OLS will capture all injectors/ignitions/etcs at exactly when we want to trigger. There is no need to capture analog outputs via the digipots since we are controlling it. With this setup, we should be able automate any kind of scenarios to capture whatever we want.
Did I miss anything? Any more suggestions?
