Eclipse cannot find Java
E4ODnut
Post by E4ODnut »
I had to remove and re-install Java for an unrelated problem and now when I try and open Eclipse it tells me it can't find JAVA JRE. A check on Java tells me I have the most up to date version. Any idea how to fix this?
Robert
Re: Eclipse cannot find Java
You can edit eclipse.ini and add the path to java as new lines on the top
here is how mine looks like:
-vm
C:/Program Files/Java/jre7/bin/javaw.exe
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
-product
org.eclipse.epp.package.cpp.product
--launcher.XXMaxPermSize
256m
E4ODnut
Post by E4ODnut »
Sorry, I haven't got a clue where to even start to do that.
Robert
Somewhere you have your eclipse folder. Somewhere in that folder you have eclipse.exe right?
Right next to it is the file you are looking for - eclipse.ini
E4ODnut
Post by E4ODnut »
Ah yes. It was there, just didn't have a .ini file extension.
Java is installed in Program Files(x86) on my computer, so I added a line similar to yours. Still no joy. Here's what my modified configuration file looks like:
-vm
C:/Program Files(x86)/Java/jre7/bin/javaw.exe-startup
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20130807-1835
-product
--launcher.defaultAction
openFile
256M
-showsplash
org.eclipse.platform
256m
openFile
--launcher.appendVmargs
-vmargs
-Dosgi.requiredJavaVersion=1.6
-Xms40m
-Xmx512m
Robert
Please install http://www.teamviewer.com/ - that's a remove PC control application, and tonight I can get into your PC and see what's going on :)
Wait a second
-vm
vs
-vm
-startup
Looks at -startup
E4ODnut
Post by E4ODnut »
Hmm. I don't see a difference there. If I open the configuration file with plain old Notepad, there is just one line, no spaces or line changes. If I open with Notepad++ there are line changes. I have no idea if any of that means anything.
I'll get Team Viewer installed
Robert
It looks like in your config "javaw.exe" is glued to "-startup" while "-startup" wants to have it's own line
