Starting engines is cool, but it all begins with working tools. Java dev console is our foundational tool and I need help with testing it.
Guys, please launch dev console, connect it to rusEfi and try to break it. Type weird stuff, click weird buttons, drag&drop... Please abuse the console and see what would go wrong. You would need SourceForge account to report bugs right into the tracker but you can simply report them here.
For now, let's begin with bugs and major usability issues - not new feature requests.
Open issue:
https://sourceforge.net/p/rusefi/tickets/46/
Fixed:
https://sourceforge.net/p/rusefi/tickets/19/
https://sourceforge.net/p/rusefi/tickets/47/
[help needed] Let's find bugs in Dev Console?
- hasse.69
- donator
Re: Let's find bugs in Dev Console?
Ha ha ha .
You asked for it....
I will do my best.
Best regards , Hasse.
I will do my best.
Either I have wrote a perfect java dev console without one single issue...
from v 3916 (july, 7) to 4662
got these errors in dev console after just clicking on 'main' tab:
exception occurred
Java.lang.IllegalArgumentException: Width (0) and height (0) cannot be <= 0
at java.awt.image.DirectColorModel.createCompatibleWritableRaster(DirectColorModel.java:1016)
at java.awt.image.BufferedImage.<init>(BufferedImage.java:340)
at sun.java2d.pipe.DrawImage.renderImageXform(DrawImage.java:487)
at sun.java2d.opengl.OGLDrawImage.renderImageXform(OGLDrawImage.java:89)
at sun.java2d.pipe.DrawImage.transformImage(DrawImage.java:264)
at sun.java2d.pipe.DrawImage.copyImage(DrawImage.java:76)
at sun.java2d.pipe.DrawImage.copyImage(DrawImage.java:1010)
at sun.java2d.pipe.ValidatePipe.copyImage(ValidatePipe.java:186)
at sun.java2d.SunGraphics2D.drawImage(SunGraphics2D.java:3169)
at sun.java2d.SunGraphics2D.drawImage(SunGraphics2D.java:3147)
at eu.hansolo.steelseries.gauges.Radial.paintComponent(Radial.java:484)
at javax.swing.JComponent.paint(JComponent.java:1054)
at javax.swing.JComponent.paintChildren(JComponent.java:887)
at javax.swing.JComponent.paint(JComponent.java:1063)
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5219)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1529)
at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1452)
at javax.swing.RepaintManager.paint(RepaintManager.java:1249)
at javax.swing.JComponent._paintImmediately(JComponent.java:5167)
at javax.swing.JComponent.paintImmediately(JComponent.java:4978)
at javax.swing.RepaintManager$3.run(RepaintManager.java:808)
at javax.swing.RepaintManager$3.run(RepaintManager.java:796)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:796)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:769)
at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:718)
at javax.swing.RepaintManager.access$1100(RepaintManager.java:62)
at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1677)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:312)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:733)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:694)
at java.awt.EventQueue$3.run(EventQueue.java:692)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:703)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
exception occurred
which engine type is rover? i entered set_engine_type 12 and got some nasty error: firmware error: findTriggerZeroEventIndex() failed
rusefi_enums.h tells us that rover is 10puff wrote:which engine type is rover? i entered set_engine_type 12 and got some nasty error: firmware error: findTriggerZeroEventIndex() failed
Try grounding PD6 for full reset - see http://rusefi.com/wiki/index.php?title=Manual:Software:User/en#Configuration_reset
I've created https://github.com/HanSolo/SteelSeries-Swing/issues/11puff wrote:from v 3916 (july, 7) to 4662
exception occurred
