GDI, v8: Gen5 LS or go home
Time to go LS. Being the most advanced open source ECU it has to be gen5 LS, right?
https://github.com/rusefi/rusefi/wiki/GM#e92
Re: Gen5 LS or go home
When working on these PnP having a patch cord helps a lot
Cam does not receive signal for first few seconds? Something is not right
Did not fire up today
- mpgmike
I'm guessing you're using a variant of the Proteus. I don't know what electronic component is used to drive the 5 volt logic signal for the LS coils, but the UAEFI uses a 3.3v-5.0v Logic Level Translator. I retrofitted LS coils on my Jeep inline 6 (4.6 stroker). It ran for less than an hour and the LLT burned out. I desoldered it and replaced it. Again the new one lasted less than an hour. Just a heads-up. Here is my thread: https://rusefi.com/forum/viewtopic.php?f=2&t=2804
Pressure goes up and then it goes down? Weird
Logs at https://github.com/rusefi/rusefi/issues/7375#issuecomment-2628483299
- mpgmike
Re: GDI, v8: Gen5 LS or go home
Are you triggering the fuel pump or is there still a factory control in place? If you're not powering the fuel pump, then the factory system probably cannot see that the engine is cranking over and turning it off after the initial prime pulse.
Yes, I can hear the low pressure pump working. Without proper CANbus I assume it over-delivers in some fail-safe mode.
Please wish me luck
We went too far on stm32s on this MVP, next revision should probably have much fewer of those.
Today was spaghetti day. Tunes and logs including searching for HPFP angle at https://github.com/rusefi/gen5-data
Hopefully PnP tomorrow.
Bluepower
jc10000rpm
is there a version of this board available ?
i have a few boards which are known to work to some extent, but overall this effort is on hold until a larger customer/partnership comes up. Will be presenting it at PRI
I would not recommend this board as your first rusEFI experience.
jc10000rpm
Thanks for the update, looking forward to hearing more
