1995 Jeep 4.6 Stroker
mpgmike
Re: 1995 Jeep 4.6 Stroker
Post by mpgmike »
Those would be the old part that has failed. The new one has "LXH8T245" stamped on it.
I have these with molex soldered
mpgmike
Post by mpgmike »
Perfect!
mpgmike
Post by mpgmike »
Finally got a "day off" to play with the Jeep and UAEFI. I got it running with the LS coil packs. I disabled everything else I previously controlled to focus on the ignition part. The timing table is what I had with the distributor. Earlier today I captured 2 emissions tests with the stock ECU running the show. After the install, I drove it around awhile to make sure it wouldn't die on me like the earlier versions did. I then did another emissions test. I will definitely have to do better tuning, but it seems to be running. Looks like the upgraded U103 is holding up (at least longer than the old one did).
I'm a bit gun shy still, so I left the factory distributor in place in case I need to do an emergency road-side swap-a-roonie. Swap ignition wires, unplug the rusEFI, and plug the stock coil back in -- back on the stock ECU.
Many thanks to AndreB for working with me on this one. He is truly dedicated to making this the absolute best platform of its kind.
mpgmike
Post by mpgmike »
With over a month of reliable driving, I am ready to dive deeper. That new TI U103 replacement is doing the trick for me.
mpgmike
Post by mpgmike »
It would appear my confidence level in the rusEFI surpassed my skeptical threshold. I removed the distributor and stock ignition coil and swapped in a later model Cam Position Sensor.
It wouldn't start! Found there was no 5 volt VREF to the new sensor connector. Traced it back to a bad crimp job on the UAEFI pin C1 (shame on me for sloppy work). Fixed that, and it started. It surged at idle, and died when I tried to give it throttle. I connected my dual-trace O'scope to the Crank and Cam sensors.
Sure enough, as careful as I was to align the shutter wheel with the pick-up to match the position in the distributor, I was off. The next picture is a screen image from the scope. I added a line (Start) where it aligned initially. The Hi/Low transition must occur between the groups of 4 pulses on the Crank Sensor. It was happening after the 1st Crank pulse. I loosened the hold-down clamp, slowly twisted the new Cam Sensor until the transitions fell about midway between the 4 pulse groupings. Had I gone the wrong direction, it wouldn't run at all. With sequential individual coils, it would have tried to fire the wrong cylinder.
On my test drive, it ran just like it did with the distributor. Next up will be to tackle fuel delivery -- including WB O2 feedback.
mpgmike
Post by mpgmike »
Spent yesterday trying to get it running long enough to start adjusting the fuel tables. I had it running the injectors Saturday night, but it would shut off after a couple seconds, then eventually wouldn't even start. Today I started checking things. The Cam Position Sensor wasn't switching (verified on a scope). Dang! Ordered a new one from RockAuto and swapped the distributor back in for now. I now have a clean Crank and Cam signal, but still no start. I checked for spark and none. Curiously, TS would go to "Offline" rather often. I'd have to shut the key off, unplug the USB cable, then start over to get communications. Checked power supply connections, all good.
Here's where it gets even better; I found an oil puddle under the engine. The engine only has <4k miles and has NEVER dripped engine oil. I checked the oil level and it was 3 quarts over full!! Apparently the rusEFI was holding injectors open constantly to get 3 quarts of gasoline into the crankcase.
I'm on my 3rd UAEFI now. When I ordered the 3rd one I saw an offer, "Buy 3, Get 1 FREE". Although I was buying my 3rd one, they were 3 separate orders. Andre was a good sport and sent me 2 for the price of 1. SOOOooo, I have a spare. I'm going to load the tune I'd been using and try again (after I change the oil).
If anyone has thoughts, I'd appreciate it.
mpgmike wrote:
Mon Sep 29, 2025 10:48 pm
You would be the first person reporting that rusEFI held injectors open.
Are there any alternative explanations? Does oil in engine look diluted/smell like gas?
Do not get me wrong - you were the first one to report uaEFI damage with specific coils, and you've turned to be right about it. Just saying that so far I am not aware of reports of injectors stuck open.
mpgmike
Post by mpgmike »
I need to spend more time with it to properly diagnose, which I will. I certainly will report my findings, even if I did something stupid and there were no electronic issues. Thank you for the response, AndreB.
mpgmike
Post by mpgmike »
I removed the suspect UAEFI from the Jeep, brought it in the house, and when I connected the USB cable to the laptop, it did a rapid connect-disconnect-connect-disconnect..... Loaded the last settings & tune into the new one and the Jeep runs again. When it failed, I had the 6 LS coils, 6 injectors, IAT, CTS, TPS, MAP, Crank & Cam sensors (both Hall), and WB O2 connected. What was different was I added the Temp sensors, WB, and injectors. The Cam sensor failed about the same time as the UAEFI if that helps.
I want to diagnose the failure, anyone have a clue where to start?
Something along the lines of https://github.com/rusefi/uaefi/issues/85?
Giobs
Post by Giobs »
Hey man!
It looks like i had a similar issue to yours with the injector stuck open (take a look at my thread), in my case I think the driver are toast, but I'm taking my time to diagnose them
mpgmike
Post by mpgmike »
I'm a bit gun-shy about diving back into the injector control again since it runs so well with just ignition control. I NEED to, but when?
I added a water vapor injection system, which bubbles the PCV gasses up through water.
I now have to spend time tuning for it. Some parts of the Timing Table feel crisper (light throttle, low RPM) while cruise feels a bit sluggish.
Not really rusEFI related, but I modified a factory "4.0 LITRE" badge to say "4.6 LITRE" and added it to the rear hatch.
mpgmike
Post by mpgmike »
Note to self: "Don't forget to save the current tune when updating the Firmware, as it WILL be either lost or, at a minimum, corrupted". Son-of-a-birch!
mpgmike
Post by mpgmike »
As they say in the SE US, "Y'all ain't gonna believe this 5h!t". I am 823 miles from home. The Jeep ran like a top -- until it didn't. I'm driving up I-81 in Virginia at 10 PM and the engine just shut off. I coasted off to the side of the road, broke out my light and checked fuses and basic stuff you do on the side of the road... Said a prayer and tried starting it. It fired! Got to the next exit where I could work without worrying about being smashed in the dark by a big rig. I happen to be "on a mission" whereas I brought an extensive collection of tools, including a portable scope. Pulled the UAEFI out of it's assigned pocket under the hood and did some back-probing of wires. Cranking I got CPS and CMS signals. It fired up in Clear Flood Mode. Great! As I twisted the UAEFI to put it back where it goes -- it died! I played with it several times, could get it to start if I positioned it just right, then get it to die by turning it around.
It is currently 12:48 PM and I am at a convenience store with a generous parking lot. I have the rusEFI situated so the engine runs, but am going to spend the night here so I can see what I'm doing in the morning (to figure something out). I have the engine running for heat (it is mid-November after all), but don't trust trying to drive it like this. Something tells me it's probably a poor crimp job (my fault) or chaffed wire (my fault), but I'm going to check for cracked solder where the headers solder to the board (would not be my fault). I'm using my phone for internet service so I can post this in the middle of nowhere. (Just venting the frustrations of my courageous adventure.)
Any updates?!
mpgmike
Post by mpgmike »
I found that if I pulled the UAEFI out of it's "pocket" under the hood, it would run fine. As I would slide it back to its pocket, the engine would die. I just left it sitting sideways for now. I continued my drive to Washington, DC without a hitch. I'm at a conference right now, will be departing for home Saturday. I don't have the tools with me to properly dive in, but will do a thorough diagnosis & repair when I get home (probably next week some time).
I checked for chaffed wires, all look good. I tried wiggling the wiring away from the UAEFI, made no difference. I pulled the cover off the unit to check for possible poor solder connections, everything looked good. I'm thinking one of the female connector pins is opened up a bit causing poor connection. Sitting the unit sideways forces a twisting of the wires that would give a better connection on the suspect pin. At this point, it's only conjecture. More to come after the show.
mpgmike
Post by mpgmike »
I'm at a loss. Some background; stock ECU controls everything except for spark. I just replaced the fuel pump with an Aeromotive E-85 pump, fuel pressure is good with key-on. I can get it to run for 15 seconds then it dies like I shut the key off. Earlier today I removed each of the rusEFI connectors and inspected the terminals. I tweaked 2 of them as they looked a tad loose, but to no avail. Bypassed the ASD and fuel pump relays, still dies after 15 seconds. To the best of my knowledge, my ZJ does not have any security system crap. Just in case, I unlocked the hatch with the key. Checked Crank & Cam sensors on the scope while cranking (one of the many times it would not start) and they look normal.
What would allow it to run for almost the exact amount of time -- 15-ish seconds -- then abruptly die? I'm posting this on the Jeep Forum as well. I don't know if I have a sensor issue, factory ECU issue, or after-market rusEFI issue.
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
Please log crancking, start and die with TunerStudio.
mpgmike
Post by mpgmike »
What data do you want to see? I wanted to see Crank and Cam sensors in the data log, but couldn't find them in the menu.
