Is this an error in the baro correction function of just the table axis name? The axis is ignition load, but its asking for baro values so I assume it should be labeled baro....then the question is does the function work correctly or is it actually looking at ignition load rather than baro?
Baro Correction error?
mk e
Re: Baro Correction error?
Yes totally a typo
https://github.com/rusefi/rusefi/commit/fddf54c9d9b3662491ef0ff2f5a3ed7c110239ba fixed now, thank you for pointing it out!
mk e
Even I see or say something helpful every now and then
Everything important looks good, just a bit awkward to setup. I'll probably order some hw to try soon.
