I am planning to install an mRE r0.6.0 in this truck that initially had a diesel engine and they installed a 1FZ-FE gasoline engine that is very popular these days, it is a 4,500cc inline 6 cylinder engine.
This engine originally has a distributor with a trigger inside, a coil and an external igniter, the plan is to convert it to Wated Spark as it comes a generation later of the same engine, which already has a 36-2 trigger on the crankshaft.
This is an image of the distributor trigger, it has 3 VR sensors, a 24-tooth trigger and a 1-tooth home trigger.
Trigger + is connected to the VR/HALL input and Home + to the HALL input, the mass of the 3 sensors is the same
This is a very good guide from Haltech on this engine with a lot of useful information.
https://support.haltech.com/portal/en/kb/articles/fz-engine
The idea I have is to use the sensor with the 24-tooth wheel and one of the 2 cam sensors, as shown in the Haltech guide, for the mRE I would use an external converter for the cam signal.
I tried this configuration on the test bench, but I can't get it to read well below 2000 Rpms, I leave the logs and the tune that I am using, keep in mind that I have not installed it yet, I am testing everything on the test bench .
https://www.rusefi.com/online/view.php?msq=1569
This video shows the behavior it has, I am moving the distributor with the help of a drill, at low speed it does not read rpms, from approximately 2000 rpms, it reads the rpms and apparently it works ok, on the small oscilloscope you can see the Home signal after signal converter
[media]https://youtube.com/shorts/3oR2Xa-9kP4?si=Z6uKbQtNRqjYQogM[/media]
The IAC valve of this motor is a 6-wire stepper, following the connection suggested by the Haltech guide, it works perfectly with the mRE.
I am still very new with mRE, I don't know why I am suddenly connected incorrectly or what configuration I need, please, any additional data or log I will be sending it to you as soon as possible
Thank you very much for your time!
