nissan HR12DDR GDI engine
Omen234
- Github Username: romioRN
purchased the HR12DDR engine. https://en.wikipedia.org/wiki/Nissan_HR_engine
Omen234
Re: nissan HR12DDR GDI engine
Omen234
It will be an airboat
Omen234
Omen234
I made a control unit for him.
Omen234
Omen234
Omen234
I've connected everything
Omen234
I made a custom firmware
https://github.com/romioRN/fw-custom-Cat-GDI
Omen234
Everything seems to be working
Omen234
now I would like to add a trigger the crankshaft trigger on it is now like a subaru ez30, but no luck with the camshafts
Omen234
void initializeNissanHRvvtIn(TriggerWaveform *s) {
s->initialize(FOUR_STROKE_CAM_SENSOR, SyncEdge::RiseOnly);
int offset = 360 - 260;
s->addToothRiseFall(offset + 30);
s->addToothRiseFall(offset + 47);
s->addToothRiseFall(offset + 150);
s->addToothRiseFall(offset + 270);
s->setTriggerSynchronizationGap2(4, 6);
s->setSecondTriggerSynchronizationGap2(0.35f, 0.7f);
void initializeNissanHRvvtEx(TriggerWaveform *s){
Omen234
The VVT is similar to the vq30, so I assumed it should be like this. but I don't understand how to implement it and verify it. explain or show, for example, dropping links to changes
please attach a perfect photo of the trigger wheel
Omen234
Omen234
Everything is very good without candles
Omen234
as soon as I put the candles on, the place stops working
Omen234
Omen234
Omen234
please try once https://github.com/rusefi/rusefi/commit/47638b3eea7c04ff3c42f8cc9dd56deeb46ab683 builds
Omen234
Omen234
Logic-1.2.40
Omen234
Omen234
Omen234
s->addToothRiseFall(120);
s->addToothRiseFall(120 + 17);
s->addToothRiseFall(240);
s->addToothRiseFall(360);
s->setTriggerSynchronizationGap2(5, 7);
s->setSecondTriggerSynchronizationGap2(0.05, 0.5);
Omen234
дабавил токой вот код для распредвала
Omen234
https://github.com/romioRN/rusefi/blob/nissan--vvt-in/firmware/controllers/trigger/decoders/trigger_nissan.cpp
вот ссылка на код иеще на тест
https://github.com/romioRN/rusefi/blob/nissan--vvt-in/unit_tests/tests/trigger/test_real_nissan_hr_vvt.cpp
не проходит тест что не так не понимаю неделю сижу не каких результатов ю что я делаю не так?
Omen234
Omen234
лутшее изоброжение которое я нашел
