Wasted spark and batch fire injection on Audi 5.2 V10
v10send
Post by v10send »
Hey guys I'm looking to run this engine on an engine stand with uaEFI and would greatly appreciate your help!
Here are some engine specifics:
Audi S6/S8 V10 engine
90 degree V angle
Split pin crankshaft configuration and results in a desired
ignition interval of 72°
Crank sensor is 60-2
Firing order - 1–6–5–10–2–7–3–8–4–9
Factory direct injection - I have converted this engine to run port fuel injection with 10 injectors.
Can someone help me with setting up some areas in tunerstudio?
Fuel setup - injection control
Ignition setup - base ignition settings
Ignition setup - advanced ignition options
Thank you! :D
Re: Wasted spark and batch fire injection on Audi 5.2 V10
What's the current state? Does engine crank? Do you have VR input wires to uaEFI? Do you have everything wired?
Any photos?
v10send
Post by v10send »
Just planning the project at this point and making sure I can do it.
The engine is just on a pallet and I bought the uaEFI board today, so still waiting for it to arrive. Haven't tried to run the engine yet.
We support odd fire, I am sure we will get it decode once you get it to spin and fire spark without fuel with sensors hooked up.
v10send
Post by v10send »
Yeah we can spin it over and see once I get the uaEFI. Looking forward to it. Thanks!
This engine is even firing by the way.
