(see https://rusefi.com/forum/viewtopic.php?p=47469#p47469)
rusEFi non-DSG VAG TCU status:
* TP 2.0 is a great tool allowing me to quickly see if TCU is still happy or no longer happy about CAN traffic https://github.com/rusefi/rusefi/blob/83ce7a3143772d4f227d9d280b87383c38910011/firmware/controllers/lua/examples/vw-tp-tcu.txt
* based on above I can produce messages which are at least not throwing TCU error code https://github.com/rusefi/rusefi/blob/2c999b9744c7fc97bb3a8d2beb28683456cb510e/firmware/config/engines/vw_b6.lua
* with all above my extremely naïve torque approximation is not good to just engage reverse on a parked idling vehicle: I get a nasty hit when I engage R
open question how many hits would this transmission survive and open question how much time I can sink into this. After all TCU control is (not) yet a priority, all I need is to smoothly drive around the block. With nasty hits engaging R I am getting close to just selling this test mule and getting a manual GDI something Will maybe sink another four hours into it and then give up.
[rusEfi] 2006 Volkswagen Passat 2.0 Turbo GDI test mule #64
Re: 2006 Volkswagen Passat 2.0 Turbo GDI test mule #64
I need to make progress or else/AndreyB wrote: ↑Tue Aug 30, 2022 1:07 amIf you are just joining let me recap
PCAN OEM traces https://github.com/rusefi/rusefi_documentation/tree/master/OEM-Docs/VAG/2006-Passat-B6
DBC with my translations of many MOTOR_* packets https://github.com/rusefi/opendbc/blob/rusefi_prod/vw_golf_mk4.dbc
https://www.efianalytics.com/MegaLogViewer/ Megalog viewer logs generated from the above files https://github.com/rusefi/can-log-tools/tree/main/output
Have I never mentioned that video from a year ago? Need help understanding what exactly do I see on the video
Also a screenshot of back-and-forth log on stock ECU - see https://rusefi.com/temp/vag.zip that's my tool converting OEM powertrain traffic into MLV using above mentioned DBC file
- javaw_toDdzSNBhn.png (178.76 KiB) Viewed 16389 times
