Reasonable priced Grayhill 12 and 20 button keypads availabe from DigiKey.
opelpanfan
Github Username: opelpanfan
Slack: Ben
Post by opelpanfan »
DigiKey has super cheap Grayhill 12 and 20-button keypads with CANOpen protocol.
12 button part code 3K012-4RN3AG CANOpen protocol
https://www.digikey.co.uk/en/products/detail/grayhill-inc/3K012-4RN3AG/9809016
20 button part code 3K020-4RN3AG
https://www.digikey.co.uk/en/products/detail/grayhill-inc/3K020-4RN3AG/9809020
It would be super nice to have support added to FW
Re: Reasonable priced Grayhill 12 and 20 button keypads availabe from DigiKey.
Just ordered one each without researching what kind of a connector it needs. Do we know part number for harness side connector?
opelpanfan
Slack: Ben
4 pin Deutsch DT connector
DT06-4S
Also very nice stickers are available from Haltech for these keypads:
https://www.haltech.com/product/ht-011500-can-keypad-label-set/
opelpanfan
Slack: Ben
Small info about how to use the keypad.
Programming manual:
3K012-4RN3AG.pdf
Default NodeId is 0x18A hex
Wake up Keypad need to send
ID = 000h, LEN = 8, Data = {01h 00h 00h 00h 00h 00h 00h}
Enough send once after power up and Init message received
ID = 70Ch, LEN = 1, Data = {00h}
Keypad clicks return with
ID = 18Ah, LEN = 3, Data = {xxh xxh xxh}
Multiple button clicks at once sum up data:
Button 1 + Button 2 will get you Data = {03h 00h 00h}
Set indicator LED's:
In total 3 LED's per button so {Number of Buttons} x 3 = 36 (in case of 12 buttons)
ID = 20Ah, LEN = 8, Data = {00h 11h 22h 33h 44h 55h 66h 77h}
00 - Control 1-8 LED's addressing in 8 bit binary (00000000) to hex (00-FF)
11 - Control 9-16 LED's addressing in 8 bit binary (00000000) to hex(00-FF)
22 - Control 17-24 LED's addressing in 8 bit binary (00000000) to hex(00-FF)
33 - Control 25-32 LED's addressing in 8 bit binary (00000000) to hex(00-FF)
44 - Control 33-40 LED's addressing in 8 bit binary (00000000) to hex(00-FF)
55 - Control 41-48 LED's addressing in 8 bit binary (00000000) to hex(00-FF)
66 - Control 49-56 LED's addressing in 8 bit binary (00000000) to hex(00-FF)
77 - Control 57-64 LED's addressing in 8 bit binary (00000000) to hex(00-FF)
Set Brightness:
ID = 30Ah, LEN = 8, Data = {xxh 00h yyh 00h 00h 00h 00h}
xx - 0-255 in hex (00 - FF) indicator brightness
yy - 0-255 in hex (00 - FF) backlight brightness
opelpanfan
Slack: Ben
Small Lua script
function onKeyClick(bus, id, dlc, data)
	if data[1] == 0x80 then
		txCan(1, 0x20A, 0, { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 })
	elseif data[1] == 0x40 then
	elseif data[1] == 0x20 then
	elseif data[1] == 0x10 then
	elseif data[1] == 0x08 then
	elseif data[1] == 0x06 then
		txCan(1, 0x20A, 0, { 0x48, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 })
	elseif data[1] == 0x05 then
		txCan(1, 0x20A, 0, { 0x41, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 })
	elseif data[1] == 0x04 then
		txCan(1, 0x20A, 0, { 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 })
	elseif data[1] == 0x03 then
		txCan(1, 0x20A, 0, { 0x9, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 })
	elseif data[1] == 0x02 then
		txCan(1, 0x20A, 0, { 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 })
	elseif data[1] == 0x01 then
		txCan(1, 0x20A, 0, { 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 })
	elseif data[1] == 0x00 then
	end
end
function onTick()
end
txCan(1, 0x000, 0, { 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 })
txCan(1, 0x30A, 0, { 0xFF, 0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00 })
canRxAdd(0x18A, onKeyClick)
Appreciate all the additional info!
