It's the first time I'm tuning such a setup, and I've decided to start out with the Speed-Density strategy.
The ECU incorporates 2x MAP sensors; one for reading MAP between the two intakes (T-ed together), and one for realtime barometric reading.
Assuming Barometric sensor is activated under "Baro sensor" in TS;
does the SPD strategy or equation implement any form of theoretical correction based on measured baro pressure, thus using the "Baro Correction" table only as an additional correction (1), or is the baro correction solely based on the values in the "Baro Correction" table (2)?
If (2) is true; how would you suggest one approaches the task of making a barometric correction table from a theoretical point of view?
I've been checking out some random speed-density maps @ RusEFi Online, but none seem to have any other values than "1.0" scattered across the "Baro Correction" table.
As a sidenote, Megasquirt has two similar strategies for SPD; "Speed Density" and "%Baro":
The latter, as far as I have figured, takes the Baro pressure into account and calculates the ratio between MAP and Baro, rather than using the raw MAP value as a load factor. This makes the load scale a percentage scale, thus letting the ECU access the entire load range regardless of barometric pressure limitations (one would never access 101kPa at the top of Pikes Peak in regular SPD mode).
To me this strategy makes more sense from the aspect of measuring actual volumetric efficiency, as the engine in principle would pump the same volume for a given throttle position/RPM regardless of air density.
Is this "%Baro" feature implied in the SPD strategy for RusEFi?
Any relevant link covering this subject would also be much appreciated. Thanks for the input
