got a BMW 2005 760Li
similar to Andreys
its for the wife
and it has turned into a black hole of work.
BMW 760Li and Angst
BMW 760Li and Angst
Re: BMW 760Li and Angst
found this in the oil pan
probably a timing guide piece
means i get to go hunting !
My Joy Is Everlasting
Germans, after having moved to the US, enjoy a bit of freedom. I say don't restrain or "guide" the timing chain and let it fly free.
- Zeiss
- Github Username: HeinrichG-V12
Outch, THIS means work..... a lot of work. This is a part of the chain tensioner, probably the tensioning bar....
Check this out: http://www.km5tz.com/BMW760iP5.htm
Wow amazing link and really unexpected turnZeiss wrote: ↑Tue Feb 15, 2022 7:33 pmOutch, THIS means work..... a lot of work. This is a part of the chain tensioner, probably the tensioning bar....
- Zeiss
The problems with "transfer pipe" are really very very rare with the V12. With the V8, it looks quite different.
The guy is a bit crazy, okay, i bit more...
i replaced the piston ring and dissecant
in the air pump for the air suspension
and it works much better now
pumps up the air springs in 30 sec instead of 5 minutes
https://www.ebay.com/itm/152579724686
nice one!Zeiss wrote: ↑Tue Feb 15, 2022 7:33 pmOutch, THIS means work..... a lot of work. This is a part of the chain tensioner, probably the tensioning bar....
DONE... so far
checked hplp for leaks
checks pressure of low pressure and high pressure pumps
cleaned carbon
set cam timing
tested evaporation valves
4 new injectors replaced
8 injectors cleaned and calibrated
fixed steering leak with new pipe
tran fluid 9 quarts and filter and gasket
NEW -->
2 swing arms front
strut bellows
abs wheel sensor
high pressure fuel sensor -- bank B ?
oil and filter
steering fluid
gasket oil pan
cam cover gaskets --2
cam sensors -2
eccentric cam sensor
pcv valves
plugs NGK
piston ring and disseciant on air pump for air springs
shock on back
brake light sensor
3 new coils ( not necessary )
JUNKYARD-->
SZL steering sensor
SIM module
yaw sensor
parking brake setup
cd player
4 rims
4 tires
cleaned carbon
set cam timing
NEW -->
2 swing arms front
strut bellows
abs wheel sensor
oil and filter
steering fluid
gasket oil pan
cam sensors -2
pcv valves
plugs NGK
shock on back
brake light sensor
JUNKYARD-->
SZL steering sensor
SIM module
yaw sensor
parking brake setup
cd player
4 rims
4 tires
you can take the parking brake assembly out of the bmw 760li without taking out the rear air conditioner.
also, you do NOT have to take off the parking brake assembly from the rear wheels.(like NewTIS tells you to do)
open the parking brake actuator all the way to the "assembly mode"
take the head of the cable off the fork of the actuator
there is a spring (tab) holding the cable housing into the actuator... push the tab down with a screwdriver.
have someone yank on the parking brake cable between the rear wheels and the actuator ( remove the rear wheels to access the cable )
its pretty obvious once you get the wheel off. just grab the cable housing and yank.
the cable and housing inside will come out easily .
no disassembly of the rear wheel required.
just so you know
keywords. E65 E66
emergency brake
parking brake
just so you know
keywords. E65 E66
emergency brake
parking brake
for WinKFP, NCSexpert, INPA, etc
VIN: WBAGN83525DKxxxxx
INPA: UIF (User Information Field) Report
1-Open INPA>
select your car model (E65)>
Functional Jobs>
HIT -->F3 UIF
2-You'll see a list of all control units with their ZUSB number and VIN
4-Identify the ZUSB numbers without your VIN and copy them on paper -- like " SZL --ZUSB--> 1234567"
and close INPA
WinKFP:
IMPORTANT!!
in configuration box... check ONLY the--- programming voltage,--- Test Checksum,--- UIF write in comfort mode. (bimmerlabs says also "UIF write after data" )
PABD format is IPO ... API is -- i use 0 (bimmerlabs says 1) ... IFH is same
you need to turn OFF "activate Bootsectorupdate " each time you boot up the winKFP.
could test "fast baudrate" and see if that works okay.
also, some modules need to have the ignition turned ON, car not running ( ALS, EDC, etc)
some modules can work with just the key stuck in the ignition .
Edit VIN and Flash Module ( make sure the config boxes for "UIF write in comfort" are checked . otherwise your VIN button will not appear. )
5-Open WinKFP (Load SPDaten files in Coding Tool before)
6-Select comfort mode
7-Then click F1 identify ECU /find ZUSB
8-write the ZUSB number you copied
9-this will go straight to the correct ZUSB- click OK
10-Then enter your full VIN on VIN tab, just the straight VIN without a checksum at end.
VIN: WBAGN83525Dxxxxx
click on TAB --> DONE
11-Double check that the module your going to flash it's safe to flash with your cable and the battery needs to be connect to another power source
12-Click on PROGRAM tab/ update ZUSB (this will flash the module with SPDaten files and re-write the VIN)
NEXT
load ncs expert
(to Code module--)
file--> load profile --> factory coding
F1 start
F3 chassis
pick --> E65
pick --> CAS
F6 back
F4 process ECU
pick one --> ( like SZL)
F3 execute job ( will kick back error if not working, like on the Tuner )
then "change ECU " for next module.
F6 back ( to start another load of code)
OPTIONAL-->>>>
NCExpert: Code to Default
13- Open NCExpert
14-Load profile -> Expertmode -> F1 -> F3 -> choose E60 from the list -> choose any module you want from this list -> now click F6 Back -> select F4 Process ECU -> choose Module -> now click ReadECU -> close the notepad window that showed up after the module was read.
15-Press F5 for basic functions -> Select "coapiReadSgGetFswPsw" and click Ok -> Select F2 "job" select SG_CODIEREN and press ok -> Press F3 Execute job and wait for the buttons to become active, when active it's all done.
NEXT
INPA: Identification Report and Clear Errors
16-Open INPA>
select your car model (E60)>
Functional Jobs>
F1 - Identification-- -Look in the SGBD column the module you replace-- write down SGBD?
and F3 to see if all the VINs match
19-Clear (EM, IM and HM) Errors and Close INPA
NEXT
ISTA
service function
body
safety modules
and run thru procedure to "start time" on safety modules-- satellite, etc
OPTIONAL -->>>>
Ediabas Tool32: Start System Time
20-Start Tool32
21-Select File->Load SGBD, Group file
22-Browse to the EDIABAS\ECU folder, and search for the file name based on the listed SGBD column. Can be more than 1 file.
23-In the Left of the window select systemzeit_lesen (write)
24-In the middle of the window Argument (value of) type 1 in the dropdown menu
25-double click systemzeit_lesen and done.
NOTES
you can do coding with the key in... do not need to turn on car.
put on a charger, to be safe .
turn off all virus protection, firewall, etc on windows 10 .
often this doesn't matter, but in some cases (such as flashing an RSA delete) the 'bootsector update' checkbox will cause your DME to brick. The annoying part is you have to 'uncheck' that box every time you open WinKFP - fortunately you can force it off. Open:
C:\EC-APPS\NFS\CFGDAT\COAPI.INI
and add this line to the end of the file:
BsuActive=OFF
"I just want to note that UIF CAS comes out with VIN "0000000" and without any problems is working. "
i reprogrammed ALL the modules on PT can bus , including the DME and EGS with the winKFP settings as above. even "bricked" modules.
disconnect the battery overnight to allow "bricked" modules that say "programming abort" to reset, then code them with WinKFP.
"Get the bimmergeeks pro cable -
useful notes --
https://bimmerlabs.com/help#supported
\If the devise is responding, it's booting and is probably just in recovery mode. Needs a valid program and calibration file to operate.
If the UIF and calibration dataset information is corrupt Windkp and NFS will not be able to identify the module. Windkp in expert mode is the tool left to flash using standard protocols. Expert mode allows flashing without module verification.
You must manually select
ecu address, ipo, prg, 0pa and 0da files.
Flash the correct program and then the calibration file.
1-Open INPA>
Functional Jobs>
HIT -->F3 UIF
and close INPA
WinKFP:
IMPORTANT!!
NEXT
load ncs expert
(to Code module--)
F1 start
F3 chassis
pick --> E65
pick --> CAS
F6 back
F4 process ECU
OPTIONAL-->>>>
13- Open NCExpert
NEXT
16-Open INPA>
Functional Jobs>
NEXT
ISTA
service function
body
safety modules
OPTIONAL -->>>>
20-Start Tool32
NOTES
BsuActive=OFF
useful notes --
WARNING!
Fix this on your E65 E66 NOW. Before your dashboard turns into a christmas tree!
The PT- CAN bus is a ribbon cable that runs from passenger footwell to the Emergency brake in the trunk.
there are TWO places that are splices.
1-- under the left rear (drivers side) seat
2-- under the front passenger feet carpet, just in front of the pass seat bolts
These splices are NOT WATERPROOF,
and any spilled drinks or rain in the back seat will puddle on this connector and SHORT OUT THE PT- CAN BUS !!
so NO communication can happen from engine, transmission, dash, brakes, etc
which makes it look like the car just go NUKED
FIX--
pull up rear seat cushion on the left side.
look for a ribbon cable in the bottom of the lake
find the black connector,
cut it out
wire the cable back together, with a 120 OHM resistor between the RED and RED /BLUE wires
POT the connection to make it waterproof ( GLUE, Epoxy, Silicone, whatever you like )
put back into a spot under the seat that is not at the BOTTOM OF THE LAKE
the connector under the foot carpet is less likely to get trashed, but still, its a non-waterproof connection right under a window .
That foot carpet connector does NOT need a resistor when you fix it. just cut out the old connector, solder wires, then POT the wires to make waterproof.
i see 7 series E65 E66 in the junkyard all the time, with no rust and good interiors... and wonder how many ended up in LKQ due to Electrical problems like THIS.
And NO independent repair shops here will touch these cars.. No Surprise...
Fuck You, BMW
First off, you did NOT need to splice under the rear seat-- run the wire all the way to emergency brake, then put the 120 OHM resistor INSIDE the Emer Brake Setup. BAD DESIGN, SHITTY EXECUTION
On the pass carpet splice, -- that splice is necessary , but make it friggin WATERPROOF.
FIX--
cut it out
Fuck You, BMW
Rear Sunroof drain on E66
the rear drains are located at the end of the unibody beam,
in front of the rear wheel,
facing inwards
peel back the plastic wheel liner, and you can reach in and mess with it on the drivers side, passengers side has pipes around, but still can reach in and pull out the plastic plug, and clean the plug
and compressed-air blowout the pipe.
my finger is inside the hole in picture
facing inwards
