Hellen64 revb 91Miata VSS
This means Hellen
Kristian
Post by Kristian »
Hi, I've wired up temp VSS signal from the dash. I have confirmed that the dash output is 5 volts when high, and 0 volts when low, and that it switches state as the car moves. I have hooked the wire up to 1M, VSS input, I have configured tuner studio to use 1M as VSS input, but I cannot see a vehicle speed reading on the data logs. I've looked at the spaghetti diagram and I can see an input called VSS IN, connected to P33. I can see the pull up resistors R20 and R23, but if I test between these resistors (in particular R32) and P33, I read some 14K Ohms. should this be less or am I misunderstanding the design? Do I need to run a link between P33 and R32 to get VSS to work?
Thanks in advance.
1991 1.6 Mazda Eunos Roadster, 5sp, Normally Aspirated
Re: Hellen64 revb 91Miata VSS
Just made an improvement in the firmware - at least we will have VSS front event counter https://github.com/rusefi/rusefi/issues/4173
But did not have a chance to test it so far :(
BeerMoneyMotorsports
Ill update tomorrow with needed jumper for vss
Kristian
Post by Kristian »
Thanks
Sorry for the delay. Remove r20 and jumper to p33. VSS circuit already has the pullup, so r23 can be completely bypassed.
Kristian
Post by Kristian »
thanks
