I've tried change every parameter and can't seem to get the Idle to 14.7. It's always running very very rich to about 10.
Is there something i'm missing?
Can someone help me?
Here's my tune :
https://rusefi.com/online/view.php?msq=971
Thanks
Sitha
Miata NB2 running too rich on IDLE
Nightsknight45
Re: Miata NB2 running too rich on IDLE
Under the idle setting, I see that you have "Use separate VE Table for idle" set to true, you can try setting this to false and go within the VE table to pull fuel until the car idles at your desired afrs.
HyperSpeedMedia
Ahhh.. thanks, I forgot about that. I'm gonna give it a tryNightsknight45 wrote: ↑Mon Apr 25, 2022 7:59 pmUnder the idle setting, I see that you have "Use separate VE Table for idle" set to true, you can try setting this to false and go within the VE table to pull fuel until the car idles at your desired afrs.
HyperSpeedMedia
Update!!! I got the Idle tuning adjusted, thanks to NightsKnights45Nightsknight45 wrote: ↑Mon Apr 25, 2022 7:59 pmUnder the idle setting, I see that you have "Use separate VE Table for idle" set to true, you can try setting this to false and go within the VE table to pull fuel until the car idles at your desired afrs.
