[help needed] NB2 Miata
NB2 Miata
MicroRusEFI PNP 0.2 for NB2 Miata VVT
Hello, I have a older board on a NB2 VVT miata. Can someone help me get it up and running? I've setup the parameter as best as I can, it still doesn't start. Can someone check out my tune to see what setting is wrong? Or is there a base tune I can used? I'm pretty new to this.
Last edited by HyperSpeedMedia on Tue Mar 22, 2022 6:00 pm, edited 1 time in total.
Re: ### PLEASE HELP - VVT NB2 Miata ###
Here is link to the tune:
https://rusefi.com/online/view.php?msq=925
It a stock Miata NB2 with VVT using stock MAF sensor.
Everything is pretty much stock, I wanted to make sure it works before doing any modifications.
I will upload cranking datalog in a few minutes
At the moment your unit has firmware from a year and a half ago. Realistically your first step is to upgrade to fresh release.
See https://github.com/rusefi/rusefi/wiki/HOWTO-quick-start
We also have https://rusefi.com/online to make tune and log file sharing easier for all parties involved. Please upload both tune and log once you have fresh firmware https://github.com/rusefi/rusefi/wiki/HOWTO-upload-tune
Your tune says "Speed Density" which is MAP, that contradicts your MAF planHyperSpeedMedia wrote: ↑Tue Mar 22, 2022 6:00 pmIt a stock Miata NB2 with VVT using stock MAF sensor.
https://rusefi.com/online/view.php?msq=925&dialog=engineChars
Ahh..thanks, let me try that
Re: NB2 Miata
Updated... finally up and running. Thanks
Re: NB2 Miata
Time for fresh firmware
- Github Username: duhafnusa4
- Slack: Jimmy *un*el
Re: NB2 Miata
Pleaaaaaase provide photos, vids, and put your log on Rusefi.com/online
All of this helps to make Rusefi better for you.
Re: NB2 Miata
I'm working on a video tonight, will post it up soon.duhafnusa4 wrote: ↑Tue Mar 22, 2022 11:44 pmPleaaaaaase provide photos, vids, and put your log on Rusefi.com/online
Thanks
Re: NB2 Miata
Finally up a video up.
Here's the link for install and first startup.
https://www.youtube.com/watch?v=BQk3PkOk3eM
Re: NB2 Miata
That's a https://github.com/rusefi/rusefi/wiki/MREAdapter72 adapter soldered onto microRusEFI F4HyperSpeedMedia wrote: ↑Thu Mar 24, 2022 12:51 amHello AndreyB, how do I konw what board I have to upgrade the firmware? There is a 0.2 in the bottom. Thanks
So it's microRusEFI F4 firmware for this unit
Re: NB2 Miata
Thanks alot for all your help...!!!!AndreyB wrote: ↑Thu Mar 24, 2022 1:29 amThat's a https://github.com/rusefi/rusefi/wiki/MREAdapter72 adapter soldered onto microRusEFI F4HyperSpeedMedia wrote: ↑Thu Mar 24, 2022 12:51 amHello AndreyB, how do I konw what board I have to upgrade the firmware? There is a 0.2 in the bottom. Thanks
