I have finally started playing with my STM32, and I've run into some questions and as others come along they may have the same problems. So I'll start by asking my questions here.
I have successfully installed ST-Link utility and followed the writeup here: http://rusefi.com/forum/viewtopic.php?f=5&t=283
First I played with the original (pre-installed) program a little (using the STM32 as a "mouse") then followed the writeup. It connected and after programing using the rusefi.hex file I reset the board and it went back to flashing all the LEDs like it had before. I re-checked things and tried again - same thing. So I tried erasing the board and that was successful (no more flashing LEDs). So I tried re-programing again and it didn't change anything. I must be missing something - any ideas what I should try next?
Troubleshooting: setting up the board with pre-compiled code
Re: Troubleshooting: setting up the board with pre-compiled
rusEfi expected behavior is
1) flash all four LEDs once - that's a 'hello LEDs' test
2) constantly flash the blue LED
3) if micro-USB is connected (the second, lower USB) we are expecting to see a Virtual COM device
So, you start ST LINK Utility,, hit Target>Program, Browse, Start. And what happens? What is the exact LED behavior?
Success now
As usual it was a user error - though I'm not sure how. When I downloaded the .hex file the first time it included some other lines of text (HTML, actually). I opened the .hex file with a text editor and realized right away that that was not right
So I downloaded the file again and all is well - flashing blue LED after reset. LD8 is also flashing red.
Next I will try getting tuner studio running I think. Tomorrow. Then to hook up to the tach output from the car!
We still have this issue that each firmware is hardcoded to run either shell or TS on microUSB
So you will probably need a USB TTL to get TS because I am stuck in FL and I can confirm if trunk is now functional or not
