Absolutely correct, here is my text for this:
So exactly the same. The picture is correct.
It is exactly what the picture shows or here one time more:bill wrote: ↑Wed Oct 13, 2021 12:51 pm12 Cylinder numbering is 1 through 6 on passenger (right) side and 7 through 12 on driver (left) side. numbers 1 and 7 are at the front, 6 and 12 are at the rear.
Ignition firing order is 1-7-5-11-3-9-6-12-2-8-4-10.
Bank-1 is the passenger side (cylinders 1 through 6), bank-2 is the driver side (cylinders 7 through 12).
1 9 5 11 3 7
F x x x x x x
2 10 6 12 4 8
F x x x x x x
Injectors and ETBs are crossed, the ignition plugs are "normal".
Are ypu looking for some special connectors? I think the biggest probleme here will be to get the big round connectors (the connectors to the rest of the car) and the connectors for ETBs.bill wrote: ↑Wed Oct 13, 2021 12:56 pmMe too!Zeiss wrote: ↑Tue Oct 12, 2021 7:21 am
Regarding wiring: I will make a new motor wiring harness, designed only for Proteus, completely new. The problem with the old is that the insulation is brittle and broken. This was already an issue when the engine was overhauled. The car is already 30 years old.
let me know where you buy your connectors/ etc for the new wiring harness
i need to buy some also
thanks!
bill
