How to clean used PCB headers
Mercedes 128 pin is not available new, the only option for Hellen 128 Mercedes is scavenging from used ECUs
About a third of the used units come pretty dirty. I've tried spraying CRC Quick Drying Electronic Cleaner but even with a nylon brash that's not enough to lift all the dirt. What else should I try?
Re: How to clean used PCB headers
Should rusEFI LLC invest $70 in a VEVOR Industry Ultrasonic Cleaner 3L New Stainless Steel Heated Heater w/Timer? For $70 it has to be an amazing piece of machinery! What fluid would help me here? I would love not to dissolve the plastic part and I would love not to have an explosion.
https://www.ebay.com/itm/391396472585
stefanst
Post by stefanst »
Try simple green. It's definitely safe and it may work.
Wow today I've learned!
https://simplegreen.com/industrial/cleaning-uses/electronics-manufacturing-cleaning/
Removal of solder-flux @ 1:1 with Crystal (followed by triple water rinse, double de-ionized water rinse and then air or alcohol drying)
jmr
Github Username: JimRowan
Slack: Jim Rowan
Post by jmr »
powerwasher?
jmr wrote:
Mon Sep 13, 2021 1:34 am
powerwasher?
Hmmm, that's an interesting idea! But things would fly away :) Need a baby power washer.
Post by puff »
basically, you need a small compressor with a small brush. may be, an injector washer? compressed gas cleaner?
dbh97
Github Username: chuckwagoncomputing
Slack: dbh97
Post by dbh97 »
MHTSOS
Github Username: MHTSOSVOODOO
Slack: Dimitri C
Post by MHTSOS »
The connector would not get damaged by the pressure washer but you'll have to secure it on a vice first.
Wonderingwobble
Github Username: Arthris
Slack: Arthris
Post by Wonderingwobble »
Since this is literally just the connector. I would try 2+2 Gum Cutter carb cleaner or Gunk Brand carb cleaner. Should be absolutely safe on the plastic. And then a long bristle parts cleaner brush to get down in between the pins if needed.
put it in the dishwasher
mck1117 wrote:
Mon Sep 13, 2021 8:45 pm
Damn, is this a brilliant or a horrible idea?! Are we concerned about me being able to eat food washed in this dishwasher later? Are we concerned about any sort of corrosion on the connector terminals?
mk e
Post by mk e »
I'm sure that would work great.....Bachelor I assume? :lol:
Fonzie
Github Username: duparq
Post by Fonzie »
AndreyB wrote:
Mon Sep 13, 2021 8:58 pm
I would not wash the food, only the dishes. My opinion. :lol:
dbh97
Slack: dbh97
Post by dbh97 »
Fonzie wrote:
Wed Sep 15, 2021 12:15 pm
https://www.huffpost.com/entry/dishwasher-cooking_b_3605859
MHTSOS
Slack: Dimitri C
Post by MHTSOS »
I have used the dishwasher several times to wash boards and it works a treat as long as it doesn't have any iron parts, they tend to rust fast. Just don't use the regular dishwasher soap because most of them are alcaline and can corrode some metals, especially aluminum.
MHTSOS wrote:
Wed Sep 15, 2021 2:40 pm
So what should I use? run it without cleaning solution at all?
MHTSOS
Slack: Dimitri C
Post by MHTSOS »
I've tried detergent for hand washing clothes, baking soda, and hand soap. Basically any detergent will work more or less as long as it's not foaming. Of course you'll have to consider the fact that you have a wife and the possibility of you sleeping outside if she finds out. I don't have that problem.
Major success with VEVOR Industry Ultrasonic Cleaner 3L New Stainless Steel Heated Heater w/Timer and diluted Crystal Simple Green
just 15 minutes + rinse with garden hose + spray with QD Electronic Cleaner + baby compressed air to dry things up, it's DAY and NIGHT improvement
