RealDash support
It's all about the code!
hugovw1976
Github Username: hugovw1976
RealDash support
Post by hugovw1976 »
Hi, I hope this is not a problem, I work with RealDash developer and manage to have connection with RealDash app (only for android on 1.9.5-beta1, beta version is only available for android, once is full tested the app be available for ios and windows) https://play.google.com/store/apps/details?id=com.napko.RealDash
Now I have connection via bluetooth with my custom board (in Proteus firmware 2021_05_04) bench tested without real motor running (only rpm and throttle position). If someone wants to test with a real working engine, they will be grateful to know that everything works well.
Screen capture:
Re: RealDash support
Great news!!!
duhafnusa4
Github Username: duhafnusa4
Slack: Jimmy *un*el
Post by duhafnusa4 »
This is awesome!
hugovw1976
Now is in the official app, no beta version. You can download for Windows, iOS, Android.
hugovw1976 wrote:
Wed Sep 01, 2021 1:40 pm
It looks like they do not parse .ini file? Did they take a random snapshot version of output region and any other version is not really compatible?
Waiting for my http://www.realdash.net/forum/ account to get activated
hugovw1976
Wed May 25, 2022 12:10 am
Check this post: http://www.realdash.net/forum/viewtopic.php?t=1281&sid=fda50c6f6e2a8a5dc52277657ae56605 You can check the way it's connected to rusefi, not by ini file (sorry it's the only way I can connect) but you can contact the realdash developer (he is very open for support) for a true support for rusefi, actually I have installed latest proteus f4 firmware and my ecu still connect to realdash (but I know it's not the best way)
Fresh version of RealDash works!
* tested realdash 2.2.5
* tested over-usb-cable
* manual-ini-selection
* feb-2023-rusEFI-release
hugovw1976
Fri Apr 07, 2023 9:18 am
Tested today with lates firmware April 2023 release Day 408 (rusefi_bundle_proteus_f4), over USB work flawless but with bluetooth HC-06 connected to usart2 (PD5, PD6 pins) connection it's unstable and connect and reconnect constantly. Don't know if it's because HC-06 module or software. I try connect with tunner studio over bluetooth and have the same trouble.
I'd say someone with 2chan or 4chan - i.e. one of boards officially with BT - should try
See also https://forum.realdash.net/t/rusefi-ecu-support/975
