the task is as follows.
we have arduino nano and transmitter MCP2515
also we have 3 separate on / off switches (which should be connected to the arduino nano)
in this picture you can see my nano connection to the can bus sender
also you see free outputs from arduino nano
the code should work like this
arduino gets power but doesn't send anything !
we turn on switch number #1 and arduino starts send ( canMasg1 delay (100) )
we turn on switch number #3 and arduino start send ( canMasag3 delay (100) )
we turn off switch number #2 and arduino stop send ( canmasag2 delay (120) )
parts pic what i used
Arduino help wanted !!!
Re: Arduino help wanted !!!
this cod what i have now
#include <SPI.h>
#include <mcp2515.h>
struct can_frame canMsg1;
struct can_frame canMsg2;
MCP2515 mcp2515(10);
void setup() {
canMsg1.can_id = 0x167;
canMsg1.can_dlc = 8;
canMsg1.data[0] = 0x81;
canMsg1.data[1] = 0x80;
canMsg1.data[2] = 0x00;
canMsg1.data[3] = 0x01;
canMsg1.data[4] = 0xFF;
canMsg1.data[5] = 0xE0;
canMsg1.data[6] = 0x00;
canMsg1.data[7] = 0x00;
canMsg2.can_id = 0x165;
canMsg2.can_dlc = 8;
canMsg2.data[0] = 0x10;
canMsg2.data[1] = 0x40;
canMsg2.data[2] = 0x00;
canMsg2.data[3] = 0x00;
canMsg2.data[4] = 0x00;
canMsg2.data[5] = 0x65;
canMsg2.data[6] = 0x00;
canMsg2.data[7] = 0x00;
while (!Serial);
Serial.begin(115200);
SPI.begin();
mcp2515.reset();
mcp2515.setBitrate (CAN_500KBPS, MCP_8MHZ);
mcp2515.setNormalMode();
Serial.println("Example: Write to CAN");
void loop() {
mcp2515.sendMessage(&canMsg1);
Serial.println("Messages sent");
delay(10);{
mcp2515.sendMessage(&canMsg2);
delay(0);{
#include <SPI.h>
void setup() {
while (!Serial);
SPI.begin();
mcp2515.reset();
void loop() {
delay(10);{
delay(0);{
Hello! As I understood, you can use this:
#include <SPI.h>
volatile bool but1, but2, but3;
volatile int x, y, z;
void setup() {
canMsg3.can_id = 0x163;
while (!Serial);
SPI.begin();
mcp2515.reset();
pinMode(A0, INPUT_PULLUP); // button 1
pinMode(A1, INPUT_PULLUP); // button 2
pinMode(A2, INPUT_PULLUP); // button 3
/*void zaderzhka(){
if(but1==LOW&&but2==LOW&&but3==LOW){
x=0;
y=0;
z=0;
} else if(but1==HIGH&&but2==LOW&&but3==LOW){
x=100;
y=0;
z=0;
} else if(but1==LOW&&but2==HIGH&&but3==LOW){
x=0;
y=100;
z=0;
} else if(but1==LOW&&but2==LOW&&but3==HIGH){
x=0;
y=0;
z=120;
} else if(but1==HIGH&&but2==HIGH&&but3==LOW){
x=50;
y=50;
z=0;
} else if(but1==HIGH&&but2==LOW&&but3==HIGH){
x=20;
y=0;
z=0;
} else
void loop() {
but1=digitalRead(A0);
but2=digitalRead(A1);
but3=digitalRead(A2);
//void zaderzhka();
if(but1==HIGH){
delay(100); //you can set here delay you need of put x
if(but2==HIGH){
delay(100); //you can set here delay you need or put y
if(but3==HIGH){
mcp2515.sendMessage(&canMsg3);
delay(100); //you can set here delay you need or put z
But look, furst, you need to kill noises occur when you turn a button on or off. I would use one of those examples of connection
#include <SPI.h>
void setup() {
while (!Serial);
SPI.begin();
mcp2515.reset();
/*void zaderzhka(){
x=0;
y=0;
z=0;
x=100;
y=0;
z=0;
x=0;
y=100;
z=0;
x=0;
y=0;
z=120;
x=50;
y=50;
z=0;
x=20;
y=0;
z=0;
} else
void loop() {
//void zaderzhka();
if(but1==HIGH){
if(but2==HIGH){
if(but3==HIGH){
Also I added one function which I didn't finished and just commented. This function decides which delay it needs to use in each case.
Now if you need a hard time operation, you will not have it.
For example, if you put delays like this: 100, 100, 120, your controller will send the first message, sleep for 100 msec, then send the second message, then sleep for 100 msec and so on. If you need to make the Arduino send messages between sendings of the first message, you have to finish my zaderzhka function. Or ask me and wait.
I rewrote the code and made it like-multitask.
Now you can just change the x, y, z values in the end of the Setup function and you'll have what you need. If you need a really hard timing, just put the x, y, z values little less than you need (because data transfering also requires some time).
Also now you just need to connect button pins to GND via buttons and you'll have what you need.
The code is here:
#include <SPI.h>
struct can_frame canMsg3;
int x, y, z;
volatile unsigned long int millisold1, millisold2, millisold3;
void setup() {
canMsg3.can_dlc = 8;
canMsg3.data[0] = 0x10;
canMsg3.data[1] = 0x40;
canMsg3.data[2] = 0x00;
canMsg3.data[3] = 0x00;
canMsg3.data[4] = 0x00;
canMsg3.data[5] = 0x65;
canMsg3.data[6] = 0x00;
canMsg3.data[7] = 0x00;
while (!Serial);
SPI.begin();
mcp2515.reset();
millisold1=millis();
millisold2=millis();
millisold3=millis();
x=100; //"delay" for the 1st message
y=100; //"delay" for the 2nd message
z=100; //"delay" for the 3rd message
void loop() {
if ((millis()-x)>=millisold1 && but1==HIGH){
if((millis()-y)>=millisold2 && but2==HIGH){
if((millis()-z)>=millisold3 && but3==HIGH){
The code is here:
#include <SPI.h>
int x, y, z;
void setup() {
while (!Serial);
SPI.begin();
mcp2515.reset();
void loop() {
not tested
#include <SPI.h>
struct can_frame canMsg4;
struct can_frame canMsg5;
struct can_frame canMsg6;
struct can_frame canMsg7;
struct can_frame canMsg8;
struct can_frame canMsg9;
struct can_frame canMsg10;
struct can_frame canMsg11;
struct can_frame canMsg12;
int x11, x12, x13, x14, x21, x22, x23, x24, x31, x32, x33, x34;
volatile unsigned long int millisold11, millisold21, millisold31, millisold12, millisold22, millisold32, millisold13, millisold23, millisold33, millisold14, millisold24, millisold34;
void setup() {
canMsg4.can_id = 0x163;
canMsg4.can_dlc = 8;
canMsg4.data[0] = 0x10;
canMsg4.data[1] = 0x40;
canMsg4.data[2] = 0x00;
canMsg4.data[3] = 0x00;
canMsg4.data[4] = 0x00;
canMsg4.data[5] = 0x65;
canMsg4.data[6] = 0x00;
canMsg4.data[7] = 0x00;
canMsg5.can_dlc = 8;
canMsg5.data[0] = 0x10;
canMsg5.data[1] = 0x40;
canMsg5.data[2] = 0x00;
canMsg5.data[3] = 0x00;
canMsg5.data[4] = 0x00;
canMsg5.data[5] = 0x65;
canMsg5.data[6] = 0x00;
canMsg5.data[7] = 0x00;
canMsg6.can_id = 0x163;
canMsg6.can_dlc = 8;
canMsg6.data[0] = 0x10;
canMsg6.data[1] = 0x40;
canMsg6.data[2] = 0x00;
canMsg6.data[3] = 0x00;
canMsg6.data[4] = 0x00;
canMsg6.data[5] = 0x65;
canMsg6.data[6] = 0x00;
canMsg6.data[7] = 0x00;
canMsg7.can_id = 0x163;
canMsg7.can_dlc = 8;
canMsg7.data[0] = 0x10;
canMsg7.data[1] = 0x40;
canMsg7.data[2] = 0x00;
canMsg7.data[3] = 0x00;
canMsg7.data[4] = 0x00;
canMsg7.data[5] = 0x65;
canMsg7.data[6] = 0x00;
canMsg7.data[7] = 0x00;
canMsg8.can_id = 0x163;
canMsg8.can_dlc = 8;
canMsg8.data[0] = 0x10;
canMsg8.data[1] = 0x40;
canMsg8.data[2] = 0x00;
canMsg8.data[3] = 0x00;
canMsg8.data[4] = 0x00;
canMsg8.data[5] = 0x65;
canMsg8.data[6] = 0x00;
canMsg8.data[7] = 0x00;
canMsg9.can_id = 0x163;
canMsg9.can_dlc = 8;
canMsg9.data[0] = 0x10;
canMsg9.data[1] = 0x40;
canMsg9.data[2] = 0x00;
canMsg9.data[3] = 0x00;
canMsg9.data[4] = 0x00;
canMsg9.data[5] = 0x65;
canMsg9.data[6] = 0x00;
canMsg9.data[7] = 0x00;
canMsg10.can_id = 0x163;
canMsg10.can_dlc = 8;
canMsg10.data[0] = 0x10;
canMsg10.data[1] = 0x40;
canMsg10.data[2] = 0x00;
canMsg10.data[3] = 0x00;
canMsg10.data[4] = 0x00;
canMsg10.data[5] = 0x65;
canMsg10.data[6] = 0x00;
canMsg10.data[7] = 0x00;
canMsg11.can_id = 0x163;
canMsg11.can_dlc = 8;
canMsg11.data[0] = 0x10;
canMsg11.data[1] = 0x40;
canMsg11.data[2] = 0x00;
canMsg11.data[3] = 0x00;
canMsg11.data[4] = 0x00;
canMsg11.data[5] = 0x65;
canMsg11.data[6] = 0x00;
canMsg11.data[7] = 0x00;
canMsg12.can_id = 0x163;
canMsg12.can_dlc = 8;
canMsg12.data[0] = 0x10;
canMsg12.data[1] = 0x40;
canMsg12.data[2] = 0x00;
canMsg12.data[3] = 0x00;
canMsg12.data[4] = 0x00;
canMsg12.data[5] = 0x65;
canMsg12.data[6] = 0x00;
canMsg12.data[7] = 0x00;
while (!Serial);
SPI.begin();
mcp2515.reset();
millisold11=millis();
millisold12=millis();
millisold13=millis();
millisold14=millis();
millisold21=millis();
millisold22=millis();
millisold23=millis();
millisold24=millis();
millisold31=millis();
millisold32=millis();
millisold33=millis();
millisold34=millis();
x11=100; //"delay" for the 1st message with 1st button
x12=100; //"delay" for the 2nd message with 1st button
x13=100; //"delay" for the 3rd message with 1st button
x14=100; //"delay" for the 4th message with 1st button
x21=100; //"delay" for the 1st message with 2nd button
x22=100; //"delay" for the 2nd message with 2nd button
x23=100; //"delay" for the 3rd message with 2nd button
x24=100; //"delay" for the 4th message with 2nd button
x31=100; //"delay" for the 1st message with 3nd button
x32=100; //"delay" for the 2nd message with 3nd button
x33=100; //"delay" for the 3rd message with 3nd button
x34=100; //"delay" for the 4th message with 3nd button
void loop() {
if (but1==HIGH){
if((millis()-x11)>=millisold11){
Serial.println("Message1.1 sent");
if((millis()-x12)>=millisold12){
Serial.println("Message1.2 sent");
if((millis()-x13)>=millisold13){
Serial.println("Message1.3 sent");
if((millis()-x14)>=millisold14){
mcp2515.sendMessage(&canMsg4);
Serial.println("Message1.4 sent");
if(but2==HIGH){
if((millis()-x21)>=millisold21){
mcp2515.sendMessage(&canMsg5);
Serial.println("Message2.1 sent");
if((millis()-x22)>=millisold22){
mcp2515.sendMessage(&canMsg6);
Serial.println("Message2.2 sent");
if((millis()-x23)>=millisold23){
mcp2515.sendMessage(&canMsg7);
Serial.println("Message2.3 sent");
if((millis()-x24)>=millisold24){
mcp2515.sendMessage(&canMsg8);
Serial.println("Message2.4 sent");
if(but3==HIGH){
if((millis()-x31)>=millisold31){
mcp2515.sendMessage(&canMsg9);
Serial.println("Message3.1 sent");
if((millis()-x32)>=millisold32){
mcp2515.sendMessage(&canMsg10);
Serial.println("Message3.2 sent");
if((millis()-x33)>=millisold33){
mcp2515.sendMessage(&canMsg11);
Serial.println("Message3.3 sent");
if((millis()-x34)>=millisold34){
mcp2515.sendMessage(&canMsg12);
Serial.println("Message3.4 sent");
#include <SPI.h>
void setup() {
while (!Serial);
SPI.begin();
mcp2515.reset();
void loop() {
if (but1==HIGH){
if(but2==HIGH){
if(but3==HIGH){
