I should be specific, I still will be doing an adapter board, but using proteus.
1986 Ford Mustang 5.0 EFI swap
- Github Username: wstefan20
Re: 1986 Ford Mustang 5.0 EFI swap
Is there any additional info on this? Should I just wait to use this platform?AndreyB wrote: ↑Sun Jan 03, 2021 6:12 pmWe are 3-8 weeks away from https://rusefi.com/forum/viewtopic.php?f=4&t=1913 potentially changing the hardware reality of rusEFI.
Nobody knows anything about it. Apparently it was developed in secret which leaves a bad taste in my mouth.wstefan20 wrote: ↑Sun Jan 03, 2021 6:54 pmIs there any additional info on this? Should I just wait to use this platform?AndreyB wrote: ↑Sun Jan 03, 2021 6:12 pmWe are 3-8 weeks away from https://rusefi.com/forum/viewtopic.php?f=4&t=1913 potentially changing the hardware reality of rusEFI.
Strange. I share your sentiment since this is supposed to be an open source project, but I'm sure there were reasons. For now I'll stay neutral since I'm new
Winner winner chicken dinner
Nothing at all wrong with that plan. When you look at the higher end ecus that's how they all do PnP, standard ecu with an adapter of some kind so everyone is using the same HW, it's the only way to support this kind of stuff, you know you have proven HW on every install so any issue with how the car runs is something with the car.
mk e wrote: ↑Sun Jan 03, 2021 7:06 pmWinner winner chicken dinner
Looks like the cheapest alternative to headers is something like this:
https://www.mcmaster.com/metals/copper-brass-and-bronze/shape~rod-and-disc/diameter~1-16/
I'm going to be using Delrin to insulate the pins as well as be a nice spacer between boards:
https://www.mcmaster.com/catalog/126/3841
It should only be a minor inconvenience to do it this way, and should be much cheaper than the alternative of cutting open connectors. Doubles by looking pretty good too!
Well, in case anyone was interested, I've been playing around with KiCad, and so far, I'm not really liking it too much, but it also isn't as bad of a transition as I thought. Working with libraries is a pain, and having to link and name everything manually is a pain.
I also caught a problem referenced in the forum for the 60 pin connector. The original designer flipped the pins so pin 1 is actually pin 60 etc., and it was killing my OCD so I fixed it.
Below is the basic outline of the board with the corrected connector (It's too zoomed out to see, but trust me, the pins are correct now).
Just got to keep trucking! Slow progress because I have to keep Googling how to do stuff vs Eagle.
I'm going to try to cram everything towards the front as much as possible so that I can eliminate wasted space and reduce cost of the board. For now, I might as well see what space I have to work with.
Fusion 360 and Eagle auto assign designators (J1, U2, etc.) to components, and it also automatically syncs the footprints with the schematic symbol. You also don't need to generate the netlist, and the design rule checker is a bit more complete.
Again, I'm probably just being nitpicky being pampered by using Fusion360 Eagle. It's worth little inconveniences like that to not pay $80+ per month, but if I weren't loosing access to Fusion I'd 100% be using it still...
Kicad does that too - it just does it only when you push the button telling it to do so.wstefan20 wrote: ↑Mon Jan 04, 2021 11:13 pmFusion 360 and Eagle auto assign designators (J1, U2, etc.) to components, and it also automatically syncs the footprints with the schematic symbol. You also don't need to generate the netlist, and the design rule checker is a bit more complete.
Push the button with the pen on paper. That will assign designators.
You also don't have to manually generate a netlist, just go to the PCB editor, and hit this button:
Thanks! Now I feel like that old man who complains about a minor inconvenience.
Definitely working way slower than I usually do, but I'm starting to get the hang of KiCad! Mind you that this is about as simple of a design as you can get
Here's the progress:
Here's the schematic (don't worry, netlist is all connected, just hid so it didn't look too messy):
I plan on ordering an ECU to double check the placement before I finalize the design and send for production, but should be close enough for me to route the wires.
Not much to look at yet, but I double checked all the pins to everything and it is all correct. I ended up wiring the corresponding pins to the one's I planned on not needing to wire at all (emissions stuff) with their stock function (except pin 38 thermactor air bypass solenoid which I left blank because I ran out of lowside switches) which still allows for extra features to replace them, but also reduced the complexity which will in turn reduce the cost. The remaining pins from Proteus I will wire to two 16 pin connectors (.1" spacing so it's pretty standard) which can be jumpered to db15 connectors if desired. This allows for the user to "upgrade" beyond the avaliable 60 pins, but again keeps cost down. I'm sure the pins provided will probably make 90% of the target audience happy enough as is.
With this approach you could quite literally plug the 100% stock wiring harness and not modify or disconnect literally anything and it run fine, which will be good for the Cali guys who need to pass emissions.
Oh, and if anyone knows how to fix the GND pin has no source error, please let me know!
I looked on a few forums and tried adding a +12V power symbol to a few pins, adding a pspice voltage symbol both with and out power and ground symbols with even more errors. I know it's probably something simple that I'm missing.
You mean an ERC failure complaining that the ground pin has no power supply? You can suppress that with a "power flag" (search that in the component picker) and wire to to the GND net.
Very very crude routing. All 12mil traces at the moment just to get an idea of trace routing. I'm not a huge fan of how I routed this. Any suggestions for improvement (aside from increasing trace width obviously)?
Obviously I do have ground fill, just hidden for viewing.
Analog/digital inputs can stay small traces - they don't pass significant current. Injector/relay/whatever outputs do however need bigger than 12 mil. Route highest current first, then noise sensitive (trigger, mostly), then everything else.wstefan20 wrote: ↑Wed Jan 06, 2021 11:39 pmVery very crude routing. All 12mil traces at the moment just to get an idea of trace routing. I'm not a huge fan of how I routed this. Any suggestions for improvement (aside from increasing trace width obviously)?
would rotating the Proteus board help at all with routing?
Very True. I intend on keeping your trace widths of 1.27mm for High Side Switches and 5V Reference, 0.762mm for Low Side Switches, and 2.032mm for 12V.mck1117 wrote: ↑Wed Jan 06, 2021 11:49 pmAnalog/digital inputs can stay small traces - they don't pass significant current. Injector/relay/whatever outputs do however need bigger than 12 mil. Route highest current first, then noise sensitive (trigger, mostly), then everything else.
I tried rotating, and it actually made the routing worse from what I could see. I hate having to cross all of these digital and analog signals, but it should still be ok.
Since this board will reside inside of a closed case, I didn't really see an advantage to adding status LEDs since you won't see them anyhow.
I would go wider if you can - remember those traces on the board are VERY short so they can't make very much heat/resistance.
What trace width would you recommend? Using a trace calculator, assuming the max trace length of 5inches on 1oz copper fr4 with a 20C temperature rise, 2mm is good for around 2.65Amps of current at 12V which I'm assuming is more than sufficient? The other traces will be carrying much less than that at their max when calculated. Is this just a safety margin?
Well, went back and increased trace width appropriately. At least according to calculations it should be able to handle the max current plus some without putting off too much heat. I had to play around with pin-assignments for hours and hours, but this layout is 1000 times cleaner. Any suggestions are welcome!
Trucking along on this design! I ordered a donor ECU off eBay for $17 including shipping (they surprisingly cost more at my local junkyards) to make final measurements!
Once I get the measurements from the donor to verify the design, and unless anyone speaks up about anything they'd like for me to change, I'll order a batch of 5 for testing!
In the meantime, I have uploaded a repo: https://github.com/wstefan20/5.0mustangProteusPnP
Looking good!
You can move this 12V MR trace to the back and avoid needing all those vias:
Also, do you really want the main 12v and 12v MR both connected together? If the ECU has a pin switched by the main relay, you want that one connected to 12V_MR, and the ignition switch connected to the other.
Hmm. I saw the stuff about the main relay in the wiki but wasn't sure if it was needed. The stock wiring has a battery constant which I assumed 12V was, and a hot in run and start which I assumed was the same as 12V_MR? I do have them wired separate on the board. Any reason to use a relay specifically? And what triggers it? Sorry. Probably just not understanding something simple.
You already have a main relay, it's labeled "EEC Power Relay" on the wiring diagram. The ECU doesn't need constant 12v - just switched 12v from the ignition switch (this one is pretty low power - maybe 100mA draw), and the 12V_MR pin, which is for higher power stuff on the ECU, to be powered by an external relay. The ECU switches the main relay on after starting up itself using whatever normal output you have configured for it.wstefan20 wrote: ↑Fri Jan 08, 2021 2:42 pmHmm. I saw the stuff about the main relay in the wiki but wasn't sure if it was needed. The stock wiring has a battery constant which I assumed 12V was, and a hot in run and start which I assumed was the same as 12V_MR? I do have them wired separate on the board. Any reason to use a relay specifically? And what triggers it? Sorry. Probably just not understanding something simple.
