Main relay output
Andreas_28023
Main relay output
Post by Andreas_28023 »
Hello
I tryed to power the microRUSEFI with 12 V on pin5. I did not get the main relay output to work. I might have connected pin 29 wrong and sent 12 V on it, but the MR output is supposed to be protected. The voltage was floating and was not able to drive a relay low side.
What do you think?
//Andreas
Re: Main relay output
Please confirm that you have GND any wire.
Please clarify if any LEDs are blinking on MRE.
pin #5 is the right pin to power MRE according to https://github.com/rusefi/rusefi/wiki/Hardware-microRusEfi-wiring
Andreas_28023
Leds lights up upon powering and board is connected to ground.
I will check back into the garage hopefully during the week or at the weekend, shoot some pictures
Andreas_28023
Connection between IC TL8888 pin 55 and PCB connector pin 29 is OK, but I have poor connection in harness to PCB connector pin.
I will check the rest of the harness on the weekend.
If it is only pin 29 that is the problem, I can do a workaround and connect MR 12 V directly to pin 1.If I have more malfunction, I will need to get a new cable connector.
//Andreas
Andreas_28023 wrote:
Tue Dec 01, 2020 5:05 pm
//Andreas
please clarify if that's rusEFI pigtail or you've crimped or else?
Andreas_28023
It's the rusEFI pigtail that I bought together with the board.
//Andreas
Tue Dec 01, 2020 6:22 pm
I have one pin not right in one of the pigtails myself. Your report makes it a second issue. Interesting :(
Andreas_28023
Is there anyway to extract faulty connectors, without the right tool?
//Andreas
Skickat från min SM-N960F via Tapatalk
Tue Dec 01, 2020 10:32 pm
I do not have a video, but you can take it apart with just a small flat screw driver. There is a sliding latch and there is a lock covering the rear side of the pins.
Andreas_28023
Do you know which side the latch is?
//Andreas
Both grey pieces come out.
Bottom grey piece moves out you have to pry that large side.
Top grey piece goes up, you have to prey from both sides.
That's all after you remove top black wire cap.
Andreas_28023
I extracted gray lock and pushed in pink 29 into position.
Seams to be working now.
//Andreas
Simon@FutureProof
Slack: Orchardperformance
Post by Simon@FutureProof »
Good to see you managed to resolve this, I have moved this to Hardware as it was a hardware issue.
@Andrey - Is it worth me checking the pigtails I have here?
