Getting awfully close to testing in the car first time. Have been installing the harness adapter and got everything set up, calibrated and tested including the dual DBW system. Unfortunately, the battery got drained while leaving the ignition on for a long time (the sound amplifier apparently has a fairly high standby current consumption while active
), so while I'm waiting for charging, I thought I'd do some more bench testing.
I'm still very confused about the trigger setup situation: the current .msq has been uploaded to RusEfi online:
https://rusefi.com/online/view.php?msq=614
I'm currently running the Proteus nightly build from "20210714", but the following characteristic have been observed on multiple releases and NB bundles.
My bench tester still only has a single 36-1 motorized trigger wheel with a single VR sensor (connected to "VR1").
In addition, just to be 100% certain, I have de-soldered the "VR2" pullup between the MAX9926 output and MCU, and disabled injectors/coils for zero noise operation. It should't matter anyway, given that ONLY "VR1" has been configured as an input.
As far as I can understand, current config setup should't look for a cam sensor, but regardless of settings, the trigger log clearly shows what looks like a camshaft input (one green trace pulse per 720 degrees). It does also correlate with "Trigger angle advance"; the green pulse appears at the same point relative to the missing tooth as the value defined under trigger settings - eg. if i set "180", the green pulse appears right in the middle of the two missing teeth in the log. 287 deg defined during the screen capture above.
Worth mentioning is that the "cam signal" appears just the same if I'm running the internally generated ECU stimulator "Trigger Simulator" feature.
Further, if I activate "Individual coils" under Ignition mode, I get direct spark (firing on coil at a time) as if a cam signal were present.
The same applies for injectors in fully sequential mode. This shouldn't be possible given the current setup and hardware. How and why is this happening?
The reason why I'm particularly concerned about this is that I have a cam sensor set up on my engine ready to run fully sequential/direct spark, but if I can't make logical sens of these settings to produce the results I'm looking for, I'm reluctant to get it all set up IRL. Especially since my 3D printed intakes probably wouldn't like a back-fire during overlap because of engine phase issues
