kb1gtt wrote: ↑Wed May 27, 2020 11:47 am
Does your school have FEA software? It would be cool to run simulations on electrical components, and example circuits. I currently want to know more about how thermal relief on via's work, and when they should be used.
yep, i primarily done the pcb itself but i dont have much FEA experience, everything except the uC, the TLE8888 and the Bluetooth is in the process of eletrical simulation.The priority right now is to see if we can put logic level power mosfets in the coil drivers, FQD12N20LTM was the best candidate so far as the rds at 5V was very low, that would remove the need of heatsinks commonly found in the igbt designs, the Achilles' heel of the FQD12N20LTM is the 200V of breakdown voltage, we don't now if 200V peak at the primary could be sufficient for a good spark, we are using a cb600f engine and original ignition coil.
Because of financial constraints we are following the philosophy of "overthink and simulate everything 3 times"
before the virus outbreak we had the task of maintenance of previous designed systems and creation of new ones, now with the classes and maintenance out of the way we are going full throttle at R&D, we had the schedule of 3 years to accomplish this challenge (most of the team before this initiative knew nothing more than Kirchhoff law and had zero ECAD experience) but now i feel confident that we can do this before 2021, we cant evolve if we keep in our comfort zone.
kb1gtt wrote: ↑Wed May 27, 2020 11:49 am
I think that MAXFem could be used to generate the heat generated profile, then perhaps it could also be used to show how the heat moves around on the PCB. Perhaps CAELinux could do it. Both potential solutions are to big for me to take on these days. But perhaps you have some more time than I have. Or perhaps you can work int into your school studies.
I think i forgot to properly explain, I am the electric and electronic lead of an FSAE team , my division has 5 electronic engineering students, the team has ~30 members, mostly in the mechanical engineering. They are the guys with huge experience in FEA software, right now i am trying to communicate them what problem i need solved (what is cº/W in the datasheets, etc) honestly, i myself would use app notes to eyeball everything heat related but we must justify every aspect of the design to the competition judges and more data = more points.
