[info] Greetings
Greetings
Since I stumbled upon this project and reasonable options for tuning my ride are otherwise non-existent, here I am. The intended use is a 94 Ford Taurus SHO with 3.0 and MTX. The factory ECU doesn't meet all the needs I have and this project seems to be the most economical.
Josh
94 Ford Taurus SHO
Frankenso in progress
94 Ford Taurus SHO
Re: Greetings
That stock ECU what connector is it using? How many pins? We are trying to make some relevant breakout boards.
Re: Greetings
Ford uses something called EEC-IV. It has 60 pins in a three-row arrangement. Later they had an EEC-V starting in 96. It has 104 pins in a four row arrangement.
Josh
94 Ford Taurus SHO
94 Ford Taurus SHO
Re: Greetings
So you have 60 pins? https://rusefi.com/forum/viewtopic.php?f=4&t=1684
