[rusEfi] Micro Rusefi for a Renault K4M engine #58
JPh
My project is to tune a MRE for a K4M engine. The idea is to have a stand alone ECU for trackdays with its own loom and easyly go back to OEM for street use. I will share the steps I follow so perhaps readers will not have to search on the forum, wiki, github, slack channels to find some informations.
JPh
Re: Micro Rusefi for a Renault K4M engine
First step : connect the MRE to tunerstudio.
Some problems with the drivers (see micro rusefi connection to tunerstudio https://rusefi.com/forum/viewtopic.php?f=5&t=1671).
Now everything is working and some hours will be necessary to use all the features.
JPh
Re: Micro Rusefi for a Renault KM4 engine
Next step : cut an OEM loom from a spare engine to make the mre one. Need it to calibrate the sensors and for the bench tests. With the mre connector it's easy to make.
We need more threads like this, thank you!
JPh
You help me a lot making such a product available. Open source and co-desing are great!
JPh
Today construction of the flywheel drive.
Why bother with hardware when we can simulate it?
Because real world signals learn you more about functioning, gap limits, voltage increase with rpm, sync loss...
I have all I need handy, so I jumped in.
À VR simulator is also on the list, I don't want to spin my heavy OEM wheel 10000 rpm...
When I will go for an aluminum flywheel, the different trigger wheel will also be worth a spin.
JPh
It's running!
60 to 5000 rpm
JPh
I'm limited by motor power, and fear getting the flywheel flying...
High rpm test will be done with function generator.
I will capture the signal at 5000 and feed the wave form in the generator and then go up in revs.
But I have to find an amplifier to get the right voltage level.
I will post a 60 and 5000 rpm sample for reference purpose.
Thank you for amazing content!
JPh
I hope there be more to come!
JPh
Here are the waveforms for low and high speed :
If there are some data scientists in the community : attached the samplings corresponding.
Sensor gap 0,5mm.
Sensor gap 0,5mm.
JPh
Some data calculated from the above test :
Rpm 71 peak to peak 1,1v
Rpm 5555 peak to peak 88v
dexter_lab
Looks VR by the book
the TLE8888 will handle it. It will be interesting to see how it look like when ignition is attached. Do you plan to simulate with hardware as well?
JPh
Yes my MRE will be tested with hardware up to 5500 rpm.
From that point to max possible it will be tested with a signal generator.
JPh
Now that injectors and coils are running, it will be time to test sync with spinner
JPh
Not much time to test today.
First run the vr sensor was wired inverted : there were two big spikes on the fast logger with the shorter first. Mre worked with 60/2 trigger but timing was not on mark.
Inverted the vr wires spikes are in order after but 60/2 trigger didn't work anymore.
Switched to 60/2 vw had sync losses at low speed.
Need more research and work on the system.
What do you mean timing wasn't on mark? The trigger logger page in TS should show 58 short teeth, then one tooth that's 3 times the height. You also don't need to swap the wires - there's an option in the trigger input page to invert the trigger polarity.JPh wrote: ↑Wed Mar 25, 2020 7:31 pmNot much time to test today.
JPh
To test I ran on fixed advance, setting it to 0.
I don't know what is 0 advance for rusefi.
On other systems it's during the large tooth and the next normal tooth is number 1.
During the different tests I made, the timing light showed a point in the large tooth, this point changed dured the different test I made.
But this was not the problem for me : the problem was with inverted vr 60/2 setting for trigger worked but shifted with rpm.
With normal vr wiring 60/2 stopped to work and 60/2 vw worked but only at high rpm. At slow rpm the mre lost sync randomly for a short moment an re synced and so on.
JPh
After some more work and with Gwendal's help, mre is working now.
My problem was an operator's error. I mis interpreted TS fast logger : I thought that the mid long tooth followed by the long tooth was the sign of an inverted vr polarity. This was wrong, if inverted both 60/2 and 60/2 vw were no more working.
With a working sync I could check ignition accuracy.
First with an old timing light. I saw some stability problems that needed more checking. With the scopes, the problems disappeared so my timing light has triggering problems.
I decided to make a new test setup to have real world results. I know you cannot pick up the vr signal to sync the scope. There are common ground problems which make the ecu malfunction.
So I added an other vr sensor only for scope sync : There is an angle between the two sensors, So I set the fixed ignition advance to 2 degrees which compensated this angle.
Here the résultats for different rpm :
750 rpm 2500 rpm 4000 rpm 5700 rpm For me these are very good results.
Looks great, that's a good test!
JPh
This (sunny) afternoon, MRE found its place under the hood of the Secma F16.
It's just over the oem ecu, attached to the 4 ignition drivers who are clamp bolted to the frame tube.
The loom will be easy to route over the oem one and the ecu is on the cool side of the engine.
Oh it's behind the driver?! https://en.wikipedia.org/wiki/Secma_F16
JPh
Yes, so the USB cable won't be too long to log for tuning.
Hey, that thing is just an 80% scale Lotus 340R!
JPh
Some more pictures for those who need inspiration about mechanical setup :
I am not sure how reliable this would be without rusEfi stickers.
I understand the rusEFI sticker gives you an extra 10 HP.
