Hello guy's and gal's! I need any and all recommendations that you can give me. I'm building a Porsche 914-4 powered rail buggy and wanting to convert it from carbs to EFI. Basically all that I will have involved with the system is 4 injectors, 2 throttle bodies, a single 02 sensor and 2 MAF sensors ( 1 on either Throttle body ) and some type of controller. I will be picking up my tach signal from the distributor to signal the firing of the injector.
My question is what controller board/kit do I need?
[help needed] New and Need Help! Carb to EFI
Re: New and Need Help! Carb to EFI
2X MAF? Any chance that is MAP? Why are there 2X of them? I'm assuming it's an horizontal engine with one carb out each side.
For crank angle how many pulses per rotation do you have? Also do you have a cam signal to indicate 360 degree, vs 720 degrees?
What kind of spark plug system are you running? I'm mostly interested in where your igniter is. Are you planning for fuel and spark, or just fuel?
From a physical stand point, I think the Frankenso gets you there. My concern is software. We currently run one MAP or MAF to control fuel. A question for russian, how hard would it be to allow a 2nd map or maf, to control injectors 3 and 4?
It looks like this discussion is being brought up over here. Please migrate this discussion to here https://rusefi.com/forum/viewtopic.php?f=2&t=1485
Thank you sir. I’ll check it out!
