I'm looking for a specific 60 pin ecu connector to try implementing rusefi in a plug and play application. Its found in the aem infinity but looking at the pictures it is 4 pins short but the connector looks exactly the same as what i need. Closest I've gotten is this connector from Mouser but this is the female side, i need the male side of this connector.
https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/284742-1?qs=sGAEpiMZZMs7eK6h2EBtKvTov4qbbx0DCnMfJoRc06M%3d
this is the connector from aem infinity(the blue one):
60 pin ECU connector
Re: 60 pin ECU connector
What exactly are you looking for? Are you looking for male part number? Are you looking to buy actual connector? Anything else?
CONNECTOR IS SUITABLE TO BE MATED WITH COUNTERPART P/N 284617-1
Ahh thats not the one.
Yes I need the male side but it has to have 60 pins, all of the same size. 4 rows of 15 pins per row.
This is the exact connector I need:
You should use online chat feature on TE website. TE has amazing customer dupport. If its a TE connector they would help online.
