Do not reinvent the wheel!
you need to set everything as 2.2T AAN engine.
and Turbo too
I have 2.2T (ADU) for a long time.
built 7A engine turbine.
If you do not push the boost greater than 1 bar all will work in the stock motor
Audi 80 automatic ac connector which fits perfectly to the second gen. 7A stock engine wiring loom.
Was quite hard to get that connector of that old bord, but the heatgun did the trick.
ordered parts:
- LT1084-CP5 5V/5A low dropout fixed voltage regulator
- some universal pcb's 150x200mm
Hello, i'm here new building some ecu for my 7A, i'm very new with this engine but please, can you reply me what is the partnumber for this 4 plug 7A? or do you have any links? thank you.
and if you have wiring diagram because i'll build my pcb too.
thank you so much, I can pay if want...
