USB port usage
It's all about the code!
tomiata
USB port usage
Post by tomiata »
Question on how others are using USB serial ports.
I'm connecting to a Linux laptop so your mileage may vary.
1. Discovery mini USB programming port at "top" of the board.
For programming firmware, also will power Discovery board for testing/programming.
To be safe, I unplug wiring harness from the car before programming.
2. Discovery micro USB port for console or Tunerstudio. I swap between them running one or the other. Runs fine at 115.2k for either java console or TS.
But connecting to console for me with Linux about 1 in 5 times will crash rusefi firmware with red-led-of-death. Is anyone else seeing this problem?
3. Frankenso micro USB port, should work for TS at 38.4kb.
Has an issue with power on some Frankeso boards. I do not use it since I have not been able to reliably use TS and java console at the same time.
