[rusEfi] Two stroke Efi (#14)
Re: Two stroke Efi (#14)
Very nice, very nice. Congratulations.
Need calibrate my map sensor. How can i get the specs of it? There's a easy way?
MAP is usually linear, u need two points. Weather report would tell u your atmo pressure, about 100 kpa. Then you need another point with some vacuum.
100kpa @ stoped engine and maybe 50kpa @ 10k rpm?
Some times you can use a hand pump or hand vacuum pump, connected with a gauge. A bike pump and compression gauge might work.
Andrey , please take a look on this vídeo and compare the 2 tps gauges.
https://dl.dropboxusercontent.com/u/33323872/Recording%20%231.mp4
Looks like your TPS settins are not set yet? rusEfi does not know which voltage means 0% and which means 100%Number-One wrote:Andrey , please take a look on this vídeo and compare the 2 tps gauges.
TunerStudio 'Tools->Calibrate TPS' could help, or you can just do the same thing manually - tell me your 0% and 100% 'adc' value
Tps is calibrated, you can see the diference on the 2 gauges, tps position and adc tps adc, tps position jumps from 0 to 100%.
one gauge is showing TPS voltage (tps adc, 0-1023)
another gauge shows TPS position (0-100%)
what are your TPS calibration values?
closed 43
opened 300
opened 300
can you please do
tpsinfo
in rsuEfi console a couple of times at different adc values and post the output?
tpsinfo
2015-05-11 21_59: CommandQueue: SerialIO started
2015-05-11 21_59: SerialManager: Opening port: COM6
2015-05-11 21_59: EngineState: confirmation_~:1
2015-05-11 21_59: EngineState: switching to binary protocol
2015-05-11 21_59: PortHolder: Sending [get_bit 1496 5]
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=0 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=256 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=512 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=768 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=1024 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=1280 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=1536 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=1792 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=2048 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=2304 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=2560 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=2816 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=3072 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=3328 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=3584 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=3840 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=4096 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=4352 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=4608 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=4864 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=5120 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=5376 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=5632 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=5888 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=6144 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=6400 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=6656 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=6912 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=7168 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=7424 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=7680 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=7936 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=8192 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=8448 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=8704 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=8960 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=9216 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=9472 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=9728 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=9984 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=10240 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=10496 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=10752 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=11008 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=11264 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=11520 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=11776 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=12032 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=12288 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=12544 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=12800 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=13056 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=13312 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=13568 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=13824 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=14080 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=14336 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=14592 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=14848 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=15104 size=184
2015-05-11 21_59: PortHolder: confirmation_get_bit 1496 5
2015-05-11 21_59: EngineState: confirmation_get_bit 1496 5:14
2015-05-11 21_59: EngineState: bit @1496/5 is 1
2015-05-11 21_59: CommandQueue: got valid conf! ~:1
2015-05-11 21_59: EngineState: WARNING: ADC: should not be asking for NONE vbatt
2015-05-11 21_59: CommandQueue: got valid conf! get_bit 1496 5
2015-05-11 21_59: CommandQueue: Took 5 attempts
2015-05-11 21_59: PortHolder: Sending [get_int 1512]
2015-05-11 21_59: PortHolder: confirmation_get_int 1512
2015-05-11 21_59: CommandQueue: got valid conf! get_bit 1496 5:14
2015-05-11 21_59: EngineState: confirmation_get_int 1512:12
2015-05-11 21_59: EngineState: int @1512 is 400
2015-05-11 21_59: CommandQueue: got valid conf! get_int 1512
2015-05-11 21_59: CommandQueue: Took 7 attempts
2015-05-11 21_59: PortHolder: Sending [get_int 1408]
2015-05-11 21_59: PortHolder: confirmation_get_int 1408
2015-05-11 21_59: CommandQueue: got valid conf! get_int 1512:12
2015-05-11 21_59: EngineState: confirmation_get_int 1408:12
2015-05-11 21_59: EngineState: int @1408 is 0
2015-05-11 21_59: CommandQueue: got valid conf! get_int 1408
2015-05-11 21_59: CommandQueue: Took 6 attempts
2015-05-11 21_59: PortHolder: Sending [get_int 532]
2015-05-11 21_59: PortHolder: confirmation_get_int 532
2015-05-11 21_59: CommandQueue: got valid conf! get_int 1408:12
2015-05-11 21_59: EngineState: confirmation_get_int 532:11
2015-05-11 21_59: EngineState: int @532 is 20
2015-05-11 21_59: CommandQueue: got valid conf! get_int 532
2015-05-11 21_59: PortHolder: Sending [get_float 568]
2015-05-11 21_59: PortHolder: confirmation_get_float 568
2015-05-11 21_59: EngineState: confirmation_get_float 568:13
2015-05-11 21_59: EngineState: float @568 is 1.00000
2015-05-11 21_59: CommandQueue: got valid conf! get_int 532:11
2015-05-11 21_59: CommandQueue: got valid conf! get_float 568
2015-05-11 21_59: CommandQueue: got valid conf! get_float 568:13
2015-05-11 21_59: CommandQueue: Took 10 attempts
2015-05-11 21_59: PortHolder: Sending [get_int 536]
2015-05-11 21_59: EngineState: confirmation_get_int 536:11
2015-05-11 21_59: EngineState: int @536 is 0
2015-05-11 21_59: PortHolder: confirmation_get_int 536
2015-05-11 21_59: CommandQueue: got valid conf! get_int 536:11
2015-05-11 21_59: CommandQueue: Took 8 attempts
2015-05-11 21_59: PortHolder: Sending [get_int 920]
2015-05-11 21_59: PortHolder: confirmation_get_int 920
2015-05-11 21_59: EngineState: confirmation_get_int 920:11
2015-05-11 21_59: EngineState: int @920 is 5
2015-05-11 21_59: CommandQueue: got valid conf! get_int 920
2015-05-11 21_59: PortHolder: Sending [get_int 924]
2015-05-11 21_59: PortHolder: confirmation_get_int 924
2015-05-11 21_59: CommandQueue: got valid conf! get_int 920:11
2015-05-11 21_59: EngineState: confirmation_get_int 924:11
2015-05-11 21_59: EngineState: int @924 is 38
2015-05-11 21_59: CommandQueue: got valid conf! get_int 924
2015-05-11 21_59: CommandQueue: Took 11 attempts
2015-05-11 21_59: CommandQueue: got valid conf! get_int 924:11
2015-05-11 22_00: PortHolder: Sending [tpsinfo]
2015-05-11 22_00: PortHolder: confirmation_tpsinfo
2015-05-11 22_00: CommandQueue: got valid conf! tpsinfo
2015-05-11 22_00: EngineState: confirmation_tpsinfo:7
2015-05-11 22_00: EngineState: tps min 193/max 43 v=0.23 @PA3
2015-05-11 22_00: EngineState: current 10bit=41 value=0.00 rate=0.00
2015-05-11 22_00: CommandQueue: got valid conf! tpsinfo:7
2015-05-11 22_00: EngineState: WARNING: ADC: should not be asking for NONE vbatt
2015-05-11 22_00: EngineState: tps min 193/max 43 v=0.24 @PA3
2015-05-11 22_00: EngineState: current 10bit=37 value=0.00 rate=0.00
2015-05-11 22_00: CommandQueue: Took 2 attempts
2015-05-11 22_00: EngineState: current 10bit=40 value=0.00 rate=0.00
2015-05-11 22_00: EngineState: tps min 193/max 43 v=0.66 @PA3
2015-05-11 22_00: EngineState: current 10bit=117 value=0.00 rate=0.00
2015-05-11 22_00: EngineState: tps min 193/max 43 v=1.21 @PA3
2015-05-11 22_00: EngineState: current 10bit=208 value=100.00 rate=0.00
2015-05-11 22_00: EngineState: current 10bit=207 value=100.00 rate=0.00
2015-05-11 22_00: EngineState: tps min 193/max 43 v=1.60 @PA3
2015-05-11 22_00: EngineState: current 10bit=273 value=100.00 rate=0.00
2015-05-11 22_00: EngineState: tps min 193/max 43 v=1.69 @PA3
2015-05-11 22_00: EngineState: current 10bit=290 value=100.00 rate=0.00
I think I see the problem on my side, please stay tuned.Number-One wrote: 2015-05-11 22_00: EngineState: tps min 193/max 43 v=0.66 @PA3
yes, is sw problem, because on older versions was ok.
Need help calibrating my map sensor,
the map gauge only moves a litle bit.
It's possible use this sensor?
Do you have a picture and part number for your map sensor? The best way to calibrate is to find the specs online
Can´t find information about this sensor. It´s original from Honda cbf and cbr 125.
Keihin brand.
Keihin brand.
measure voltage at open air - check your weather forecast, that would be one point. do you have anything to make & measure vacuum?Number-One wrote:Can´t find information about this sensor. It´s original from Honda cbf and cbr 125.
Keihin brand.
Can you connect to a hand held vacuum pump with gauge? Then measure voltage per gauge reading.
The link to the store for this device showing it costs about $25usd. It is a very common mechanic tool.
I know this tool here, but i don´t know if i can find with the gauge, most of people buy without gauge to be cheaper. Need ask tomorow.
Perhaps you can add a gauge with a Tee or similar fittings. The gauge does not need to be connected to the hand pump, it just has to be in the vacuum hose.
Russian, need your help
After some research found some bikes and some ford and honda cars with this map signal. I belive i have this signal on my sensor.
It´s possible use this map sensor signal with rusefi?
I would guess that first we would need to convert the frequency into voltage somehow.
@, would it be possible to do that with some magic resistor and cap values on the existing RC filter before the op-amp? I believe right now we have 100R and 0.01uF or something like that.
maybe with this
This would not be a simple circuit. 50% duty cycle means it's not just a low pass filter. I played around some with QUCS looking at adding a diode and cap to function as freq to voltage converter. So far no easy solution. I might have something that produces .9V to 1.1V, but that range is blah, and it takes some time to settle out, so it's kind of a crappy solution.
What about an external microcontroller-based DAC? I believe, the simplest solution would be to replace this sensor with another type.
The programmable way would probably require another system timer, which might not be available + some development effort.
However, looking at this sensor, I believe it has some advantages over the analogue sensors: Its readings don't change with temperature; they don't require ADC circuitry; they are probably less prone to EMI, etc.
I see, so I would need to implement the digital signal processing. That could be done.
I've just ordered myself a used Ford sensor, maybe I will have the code in about two weeks.
I can do some tests with my sensor if you need.russian wrote:I see, so I would need to implement the digital signal processing. That could be done.
- abecedarian
Did you look at LM2907/LM2917 frequency to voltage converters?kb1gtt wrote:This would not be a simple circuit. 50% duty cycle means it's not just a low pass filter. I played around some with QUCS looking at adding a diode and cap to function as freq to voltage converter. So far no easy solution. I might have something that produces .9V to 1.1V, but that range is blah, and it takes some time to settle out, so it's kind of a crappy solution.
