Hello from Mexico
first, sorry for my bad english
I have 2 vw bug
one is 1995 is oem digifant but , now have a 1776cc turbo engine, first converted to megasquirt now running on vems with display
second one is 1997 oem efi and motor i hope not for a longer,
i planed to install a 87mm pistons with techline coating in top and on chambers, an engle tcs10 cam, arp bolts on con rods , and a k03 turbo, the disstribuitor have a hall sensor open colector , the injectors are all open at the same time, and msd ignition box
i looking for a ecu for my bug in the fisrt stage i want only remplace the oem ecu, the bug have a MAP(i want raeds up to 30psi), IAT, CHT(in the head and need to reads up to 210°C), TPS and hall sensor in the distribuitor,
if all goes good i want secuential injection, distribuitor less ingnition LS coils(36-1 crank wheel hall),water injection control , NO2 contrl,
and i reall want a electronic dash board, i think in something like a arduino nano with oled or 7 segment display , for rpm, vehicle speed, lambda, oil press oil temp head temp and fuel level,
im can solder smd, the smallest smd i been solder is TQFP
i hope with this ecu to build my efi dream machine
best regards
Hello from Mexico
Re: Hello from Mexico
Hello and welcome to the forum. Have you found Frankenso and the wiki? http://rusefi.com/wiki/index.php?title=Manual:Hardware_Frankenso_board
Also I dream of my own dash, see this thread. http://rusefi.com/forum/viewtopic.php?f=4&t=775 However time is a problem, so I haven't made much progress.
AldoQ
Hi
thanks
yes i read the wiki
now start to work with a frankenso in a bech and tray to make a can dash board
best regards
thanks
yes i read the wiki
best regards
can dashboard! yummy! I'd love to see detailed steps to setup can output for dashboard
