The engine is a 4L straight 6 running on straight petrol (no LPG) coupled up to a manual gearbox so no worry about keeping the original ECU to control a gearbox. At this stage the features (required) list looks something like the below:
-Control injectors/spark for 6 Cyl
-Allow expansion from N/A to boosted (Sensible to start but unsure as to finish point
-Display of relevant instruments (Ideally using the stock cluster, Some pinouts I have found for the stock ECU mentions a bus that may control the cluster. I will have to do some sniffing to find out what it is and what it does)
Now more things it would be nice to have:
-Valet mode (Or at least a more conservative tune so we can get to/from venues with less danger to the manifold)
-Knock sensors (We have never done this before so a way to know if we're pushing it too hard is probably a very good idea.
I'm sure more will get added to both lists as we get further into this.
From what I've been reading all of that should be possible with rusefi I believe. However I am a little confused as to the practical differences between the frankenstein and the frankenso boards. Is someone able to clarify the difference or point me to a side by side comparison?
Much appreciated,
Rex O'Regan
