I found this STM reasonably low cost device with CAN capability. It still needs the CAN physical interface
https://www.bananarobotics.com/shop/Robotis-OpenCM-9.04-A-Microcontroller-(Bare-Bones)
Physical CAN interface found below for under $8. That's the same chip used on Frankenso.
http://www.ebay.com/itm/SN65HVD230-CAN-Network-Transceiver-Evaluation-Development-Module-Kit-TJA1050-/171538514567
Between both of these that's STM to CAN for under $20, and basically no soldering. Hmmm from the manual posted here http://www.robotis.com/download/doc/controller/OpenCM9.04_en/OpenCM9.04_manual_en.zip it appears the CAN board doesn't have a matching pin out, so it would need some little jumpers to change the pin out.
Are there any other low cost STM CAN capable boards out there?
STM low cost CAN
STM low cost CAN
Re: STM low cost CAN
STM32F103C8T6 - Mainstream Performance line, ARM Cortex-M3 MCU with 64 Kbytes Flash, 72 MHz CPU, motor control, USB and CAN
STM32F103C8T6 ARM STM32 Minimum System Development Board Module $4.74
No soldering and includes CAN with Automotive friendly power supply https://www.olimex.com/Products/Duino/STM32/OLIMEXINO-STM32/open-source-hardware No need for programmer, just a USB cable if you need to update the firmware. Costs about $25usd.
So...a total noob here can we use this $5 board to run rusefi ?russian wrote:STM32F103C8T6 - Mainstream Performance line, ARM Cortex-M3 MCU with 64 Kbytes Flash, 72 MHz CPU, motor control, USB and CAN
Thanks
Plaz
Nope, for rusefi ems u need a $15 atm32f4discoveryplazomat wrote:So...a total noob here can we use this $5 board to run rusefi ?
See shopping list post somewhere close
The board has arrived. The bare bones ChibiOS F1 project is https://svn.code.sf.net/p/rusefi/code/branches/rusefi_f1/ and got it flashed into the board using SWD from stm32f4discoveryrussian wrote:STM32F103C8T6 ARM STM32 Minimum System Development Board Module $4.74
this chip could be used for a thermocouple project, i guess.
this is exactly the plan exactlypuff wrote:this chip could be used for a thermocouple project, i guess.
https://svn.code.sf.net/p/rusefi/code/trunk/firmware/config/stm32f1egt/
i'd prefer ads1118 rather than max chips. probably the board will require power supply ic as well (lm7805 should be enough)
