Cylinder pressure to TDC system
Just a placeholder, will add info tomorrow when we build it.
Problem: Harley does not divulge ANY information, and majority of people working with them are pretty... Empty minded.
Pickup ring is built into crank, which is completely blocked out from the world. Only reason we have info is because we have a open motor, and was able to do some basic math to calculate TDC offset. Which also appeared to be off by 10-20 degrees in the retarded direction. Calculating TDC without a timing light or cam sensor, proves to be difficult.
Idea: Simon from UK has had a great idea of using cylinder pressure as a close approximation of TDC. Use a pressure sensor, stick into spark plug hole and see Pressure peak, and use rusEFI to show difference between timing.
Problem 2: I WANT IT DONE NOOOOOOOW! So have to work with whatever I can get asap, found a pressure sensor from a ford GDI as per Matt's & Simon's suggestion.
Solution: Gonna use compression tester tube, fabricate an adapter to it on a lathe, and attach Fuel pressure sensor into it. Wire it up to proteus, and get matt to either do some magical programming to make it show the peaks, or two just look at logs and see offset.
Will add pictures as we start work on it tomorrow.
Sensor: https://partsavatar.ca/2013-2018-ford-focus-new-pressure-sensor-bosch-0261545038?gclid=Cj0KCQiA15yNBhDTARIsAGnwe0WJtMWaU_Itn2K7ZXlHvRHZkZ1aXO6vvDiKCqz-MLAzK_ybK9f4ZgsaArabEALw_wcB
m10x1 45 degree flare
Compression tester: https://www.amazon.ca/Petrol-Engine-Compression-Automotives-Motorcycles/dp/B07BKWPPDR/ref=asc_df_B07BKWPPDR/?tag=googleshopc0c-20&linkCode=df0&hvadid=335224436156&hvpos=&hvnetw=g&hvrand=3046944275065435222&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1001920&hvtargid=pla-467133934297&psc=1
Adapter: Will upload when it is created
"Dave B. 5:03 PM
Re: Cylinder pressure to TDC system
Mark I love you.
Just like its nearly impossible to find TDC with a dial indicator by looking for the top, I expect you'll have the same issue only worse with a pressure gauge. If you run a high speed log and and pick a point , say 100psi before and after TDC, then TDC will be ABOUT in the middle. With a dial indicator its exactly in the middle but piston rings leak so so the center pressure point is probably going to be touch advanced but their will also be lag in the sensor so maybe it will all just sort of work out.
I've been away from H-D stuff for a while but isn't there a side cover on the clutch side opposite the cams? The most accurate thing to do is pull that cover and find or put a mark on something rotating (or actually mount a degree wheel), then make a welding rod pointer you can move around. Then use your dial indicator to find TDC and get you pointer right, then spin it over with the ECU connected and use your timing light to get the ECU set correctly. 2 hours work tops and it will be exact.....doing it the right way will be faster and much more accurate.
2 hours tops it is not. m8 engine contains all oil there and im not drilling into the bike.
"Dave B. 5:03 PM
Look at that beautiful trace!
"Dave B. 5:03 PM
Please post a link to log file or attach .zip file. Please post an image of the physical setup.
Log: Keeping in mind phase is 50/50 hence the 5 start attempts. TDC Offset set to 0 for data reasons and due to bug
https://rusefi.com/online/view.php?log=457
- IMG_20211202_133652.jpg (4.56 MiB) Viewed 7216 times
- IMG_20211202_133649.jpg (4.32 MiB) Viewed 7216 times
- IMG_20211202_104408.jpg (2.45 MiB) Viewed 7216 times
- IMG_20211202_104403.jpg (2.81 MiB) Viewed 7216 times
"Dave B. 5:03 PM
And heres rear cylinder being tested. 315. dead on.
"Dave B. 5:03 PM
Did you destroy compression tester to make test apparatus?
I need a test tube to find TDC on honda element.
We also need to run same test on a vehicle with known TDC like miata or volvo. We need detailed fabrication instructions
...buy any compression tester ..
https://www.ebay.com/itm/313396674222?epid=19012428643&hash=item48f7e5beae:g:SF0AAOSwH1JgRwzF
..buy any pressure sensor ...
https://www.ebay.com/itm/265124922381
..and mount it together .. ??
JRD and then dont forget buy a lathe, and some pipe, and fabricate your own little adapter. Reason I havent posted what compression tester is because I rifled through a few to find the correct fitting, and got one with threads instead of latch .
"Dave B. 5:03 PM
OK ...
I know all that things. ...
but..
I have one cheap "chinese" tester, works good, and it has something UNF or NPT thread .. similar to metric M 10x1.0
....presure sensor has M10x1.0 thread ...
I can screw any M10x1.0 sensor to hose, use any kind of LOCTITE 243 glue ... a it has no preblem ..
works well ..
but..
works well ..
Thats exactly what I have! but I used pipe tape!
"Dave B. 5:03 PM
- Github Username: vl4dim1r
- Slack: brad@boal.tech
That bung you had milled out looks a lot like the spark plug thread bungs we drill out to use as O2 sensor extensions
