Hallo from Germany
ItaloManyak
Re: Hallo from Germany
Post by ItaloManyak »
Do not reinvent the wheel!
you need to set everything as 2.2T AAN engine.
and Turbo too :D
I have 2.2T (ADU) for a long time.
built 7A engine turbine.
If you do not push the boost greater than 1 bar all will work in the stock motor
Horsty
Post by Horsty »
i'm finally working on my ecu build again.
am i right that i can use the tc4427 for the injectors switching ground on inverting mode in tunerstudio?
Track: Audi Coupé Quattro R5 Bj. '89 | 2.3 Liter | 7A | 170 bhp | Perlwhite L0A9
Daily 2014- : Volkswagen Lupo Bj. '99 | 1,0 Liter | ALL | 50 bhp | Flashred LP3G --> conversion to AEX 1.4 8v 60 bhp --> conversion to AEE 1.6 8v 75 bhp
Horsty wrote:am i right that i can use the tc4427 for the injectors switching ground on inverting mode in tunerstudio?
taking your question to http://rusefi.com/forum/viewtopic.php?f=4&t=450
Horsty
Post by Horsty »
thanks. didn't read that thread properly.. . :roll:
edit: just ordered some VNP14NV04-E.
Sergio2048
Github Username: Sergio2048
Slack: dont have
Post by Sergio2048 »
Horsty wrote:
Tue Oct 11, 2016 4:04 pm
Look what i've found:
Audi 80 automatic ac connector which fits perfectly to the second gen. 7A stock engine wiring loom. :mrgreen:
Was quite hard to get that connector of that old bord, but the heatgun did the trick.
ordered parts:
- LT1084-CP5 5V/5A low dropout fixed voltage regulator
- some universal pcb's 150x200mm
Hello, i'm here new building some ecu for my 7A, i'm very new with this engine but please, can you reply me what is the partnumber for this 4 plug 7A? or do you have any links? thank you.
and if you have wiring diagram because i'll build my pcb too.
thank you so much, I can pay if want...
