I'm planning to convert my motorcycle to fuel injection. It's a Suzuki DR-Z400S with a single cylinder carbed engine.
I want to do it in 2 step. The first one is to replace the CDI by rusEFI and get it working with the carb on. The second step is to replace the carb by a throttle body.
I have scope trace from both crank sensor. the first sensor give 6 pulses per turn and the other one give one long pulse before TDC and one on TDC.
(This trace aren't from me. I'll take some recording on thoses pulses while cranking, and running later.)
For the firing, i don't think it's a big problem because I can firing on each rotation. But I don't think I can do that with injection. To identify the aspiration cycle, I plan to use MAP sensor reading or the pulses on flywheel to detect deceleration of angular speed on compression cycle (maybe just a dream ).
Any comment or hints are welcome!
