Greetings Everyone!
I'm living in the land of durifuto: Japan!
Right now I'm working on a Masters in Information Engineering, focused on software-defined radio/ GNURadio. My Bachelor's was in Economics, so I'm not a trained Computer Scientist or Electrical Engineer. Just a devoted Linux and automotive enthusiast/tinkerer.
My project car is a 1997 Toyota Chaser. Turbocharged 2.5L Inline-6 with Variable Valve Timing (Intake only), more commonly known as the 1JZ-GTE VVTi. Right now the car is running an un-tuned Apexi Power-FC.
I have a 2JZ-GE bottom end to make a 1.5JZ, increasing the displacement to 3 liters. I figured in the process I should make some other upgrades, so I need a better way to control increased boost, etc...
I've also had a long-term goal of replacing the stock dash gauges with a digital display. To do all of this, I've looked into options ranging from Megasquirt to ISIS to Android tablets. Now I think rusEFI has the most potential to meet my needs, affordably....at some point in the future.
Anyways, hope I can make some useful contributions to the effort!
Hello from Japan
Re: Hello from Japan
Welcome along, we look forward to hearing from you.
GNUradio good stuff. It's progressed quite allot sense I last paid with it. I like GRC that's cool.
How much information about your vehicle do you have? For example do you have have a MFG part number for the harness connector? Do you know your harness pin out, ect.
Noble713
I don't know the connector part numbers.
This thread on JZX100.com is probably the most comprehensive for ECU information:
http://www.jzx100.com/forum/topic/6627-1jz-gte-vvti-need-ecu-pinout-pics-inside/
Since the Power FC is a plug-and-play ECU I haven't researched the pinout/harness details much.
VVTi - sweet. I would love to add this feature once you need it
mentat-vvo
Gotta VEMS solution for JZX100 VVTi
modded by vemsecu.ru
Noble713
Well, looks like my project is going to change to something MUCH simpler. Why? Because I just wrecked my Chaser (like 6 hours ago).
Fortunately, I recently picked up a naturally-aspirated 1993 Mk IV Supra for an absolute STEAL. No VVTi. No turbo nonsense. I think playing with this car will be much closer (in theory) to the sort of NA V8 (LS swap) builds I'd like to use rusEfi for in the future.
Sorry to hear about your loss. Here's hoping that it will get better in the near future. Let us know if you have any questions.
- abecedarian
Make sure to track your voltages...
... I think your system is 0-8v for most of the sensors.
5MGE and the offspring are good engines.
