[info] Manufacturing options
So far I have used:
http://oshpark.com/- $5 per square inch, free shipping from US. Great options to try tiny modules, not an option for larger boards due to price. No assembly.
http://www.seeedstudio.com/service/ $25 for 10 pieces 10x10cm board + shipping, 5 cents per SMD pin. Hoping to get Frankenstein with some components assembled by them pretty soon. Cons: fairly limited Open parts library of components they would use for assembly.
Re: Manufacturing options
Today I have learned about another Chinese company: http://smart-prototyping.com/Prototyping-Services/Electronic-Prototyping/PCB-Assembling.html
They have pretty good reviews, per SMD pin fee is higher and minimal assembly order is higher, but they have a full 0805 component book and they source parts for an extra fee without a 100pcs minimum. The PCB cost is the same as seeedstudio.
hasse.69
Post by hasse.69 »
Do you want to download https://svn.code.sf.net/p/rusefi/code/trunk/hardware/rusefi_hardware_history/frankenstein_rev00.10/gerber/gerber.zip unzip remove "assembly instructions" files to reduce confusion, zip it back and ask them for a quote say for 30 pieces? :)
hasse.69
Post by hasse.69 »
Done that.X2
X3
X4
hasse.69
Post by hasse.69 »
request sent to:
http://www.sunsoartech.com/
http://yhpcb.en.alibaba.com/
http://sky-macau.com/
http://pcb.hqew.net/
If they have additional questions i will ask here.
Hasse.
hasse.69
Post by hasse.69 »
That is one of the vendors i´ve sent a request to.
Did we ever hear back from any of the above inquires?
I also recently discovered http://www.elecrow.com/services-c-73/prototyping-service-c-73_120/pcb-assembly-p-366.html which seems to be almost the same as SeeedStudio's service.
Nobody
Post by Nobody »
If made in the USA means anything, then http://www.4pcb.com/bare-bones-pcbs/index.html?gclid=CLrUzsjLz74CFYtAMgodTxYA2w been very happy. Know it's not the cheapest place.
UnaClocker
Post by UnaClocker »
http://www.smallbatchassembly.com/ This place is hobbiest friendly, much like OSHPark and OSHStencils, if you need to have a batch of boards with tiny SMD stuff assembled, it might be a viable option.
Brian from Tacoma, WA
84 Dodge Rampage
01 PT Cruiser
Just a note, elecrow does PCB assembly.
https://www.elecrow.com/services/pcb-assembly.html
Another pretty cheap option https://jlcpcb.com/quote
russian wrote:
Tue Sep 19, 2017 1:23 am
Googling "why is jlcpcb so cheap" gives us an interesting discussion https://www.reddit.com/r/PrintedCircuitBoard/comments/9bt5ed/how_come_jlcpcb_be_so_cheap_compared_to_others/ with the OSHPark guy teaching us new words like Tg130, Tg140 vs Tg180.
I am not making a huge secret from the fact that current source of Frankenso PCBs and assembled boards is not exactly perfect - we've definitely seen a couple of PCB defects. And that's while being quite more expensive than jlcpcb.
Actually @ has an assembled board which gave me some magic sparks on first 12v power on.
Old Grey
Post by Old Grey »
In the past year I have read 3 cases of traces falling off PCBs when a burnt component was changed, but I don't know who the PCB manufacturer was. The 2 layer JLCPCBs that I got recently didn't lose any traces, and I applied a lot of heat fixing the FUs you didn't see, but I don't know about complicated stuff like 4 layer.
The assembly shop I am using currently does not have a website?! Maybe they are just a small one person broker I guess/ https://twitter.com/tingriverpcb
Wed Feb 19, 2014 9:56 pm
They have since added parts supplier https://www.seeedstudio.com/opl.html they now have STM32F407VGT6 for instance
A new alternative?
Wow, really surprised to see digikey joining this market! Great news for us I guess.
sort of news from jlcpcb
Mck1117 reminds if ordering boards that we know will need fine pitch SMD done by hand, we should get ENIG instead of HASL regardless of jlcpcb or not
Once in a while JLCPCB is less amazing
MHTSOS
Github Username: MHTSOSVOODOO
Slack: Dimitri C
Post by MHTSOS »
I can't really tell by the pictures but it doesn't look like solder has flowed up the IC leg.
Whole universe of kicad vs jlc drama, I've stumbled over https://github.com/matthewlai/JLCKicadTools hopefully that would be THE answer.
Wed Mar 29, 2023 9:22 pm
Feels like JLCPCB assembly quality goes down :(
I've soldered connectors on four units this week.
One of two Hyundai has inop MAP sensor input :(
One of two Honda units has inop VVT output :(
Cnc thru hole machine video below.
Well at least this time JLC has email me the pictures and this time they blame me for not mentioning stm32 temperature limitations.
Wow.
