[help needed] Electronic Variable Valve Timing Actuators
Let's start with Renault Nissan (?) part number 237535TA2A
Electronic, very much with brushes... Half of the actuator sits on the cam, the other is inside the black magic? See the video for yourself.
Re: Electronic Variable Valve Timing Actuators
Next goes Mazda 235100-0873 which might be used on ND2 Miata. Next step is finding one for under $100 in US or sourcing from Europe :)
Hyundai went simpler, just the brushes without the sensor?
Engine Variable Valve Timing VVT Solenoid 24360-2GGD0 Compatible with Genesis G70 2.0L 2019-2021, Hyundai Santa Fe 2.4L 2019-2020, Kia Stinger 2.0L 2018-2021, 24360-2GGB0, 24360 2GGB0
Fri Sep 20, 2024 10:57 pm
Mazda 235100-0873
What do we see?
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
Let's build a quadrocopter from 4 of this!
Dron_Gus
Post by Dron_Gus »
Wire colors...
Do we have a pinout/wiring diagram?
I'm 95% sure about 12V power and ground - this is two pin connector.
4 pin connector (actually 5 position, but used only 4) - 3 pins looks like digital inputs/outputs. And one looks like power to MCU, may be 5V?
NormanAlphaspeed
Post by NormanAlphaspeed »
Sat Sep 21, 2024 3:18 am
Two fuses for one VVT, smells like extremely high current
Dron_Gus wrote:
Sat Oct 05, 2024 8:57 pm
Wire colors...
Can I/should I get you a Hyundai one?
