My harley conversion
cpipkin6.5x55
Post by cpipkin6.5x55 »
I'm working on a 97 harley efi conversion and I am trying to sort out a tach signal for the original tach. I am planning on individual smart coils, but the original system was a wasted spark setup. Can I run 2 coils as wasted spark and draw my tach signal off one as was done originally or should I sorce a diffrent coil packm
Sent from my SM-G991U using Tapatalk
Re: My harley conversion
I've only touched newer harleys and those were V-twin odd fire meaning wasted spark was not possible. Is your engine even fire or odd fire? what is the name/model of the engine?
yes we have "two wire wasted spark" using individual coils
cpipkin6.5x55
It's a 97 80 cuin evolution motor, and yes it is odd fire with a 45 degree seperation. I know they did a wasted spark system on early models of this engine, but I don't have any experience with them.
cpipkin6.5x55
I'll add some images tomorrow
cpipkin6.5x55 wrote:
Mon Jun 10, 2024 4:41 am
i am confused I was assuming that odd fire can never be wasted spark?
cpipkin6.5x55
This is the original wiring for the coil
cpipkin6.5x55
I think I have a solution. I can convert to the efi tach that's 12v single spark, so I can wire to the negative of one coil
