[help needed] Development of Honda Beat Adapter
Loudis
Post by Loudis »
Hello rusEFI forums,
My name is Louis and I am currently working on getting my Honda Beat to run on rusEFI.
After looking at very blurry pictures of the ecu wiring diagram, and using information from "WhiteSol" Link I have come up with a spreadsheet linking most of the pins on the stock ECU to the pins on the microRusEFI. Linked below is a google spreadsheet with my current configuration and I am looking for some community oversight and recommendations. I am open to changing to a different rusEFI ECU as-well if any of the others suit my needs better.
Re: Development of Honda Beat Adapter
Linked below?
Loudis
Post by Loudis »
Conversion Google Sheet
I have come to the realization after getting a higher resolution image of the PMG-FI Full Diagram that there are 3 VR sensors. I have no issues with using an adapter to "Hall Sensors" but I believe the micro does not take TDC or CYL sensors into account. I do not know if I can continue with this on the micro or if I should change to a different controller.
That reminds me of OBD1 which also have three VR sensors. We just totally ignore one of these, two sensors do the job well enough.
Loudis
Post by Loudis »
So it'd be fine if I ignored one of the sensors, would I still have room to add protections like shutting of on sudden oil pressure drop?
Loudis
Post by Loudis »
I am back after an extended break from working on the ECU. I believe I've make a pinout that will work. I'm switching to the uaEFI and have added sheets for individual pinouts on each ECU (Stock and uaEFI) along with a sheet dedicated to the conversion sheet. I'm hoping someone can look it over before I bite the bullet on purchasing the required connectors to adapt everything.
https://docs.google.com/spreadsheets/d/1AWHIYRkrcUGH1Putkja4jguDhpA-nawyu_q7Jba2lHs/edit?usp=sharing
