2 wide band o2
cpipkin6.5x55
2 wide band o2
Post by cpipkin6.5x55 »
On a v twin engine can I took each cylinder Independent of each other at the same time with 2 wideband o2 sensors? Or can I only tune a single bank at a time? I'm trying to see the advantage of dual o2 sensors.
Sent from my SM-G991U using Tapatalk
Re: 2 wide band o2
I strongly suggest two. You would be tuning 2nd cylinder correction manually.
