Here is how I transfer tune between versions
zed65
Post by zed65 »
When I want to update the ecu firmware I do as follow:
Start STM32CubeProgrammer and put the ECU in boot-mode and connect.
Hit the erase all button.
Open the new .hex file and program the ECU
When it's all done I start TuneStudio and create a new project.
Choose the .ini file from the same folder that the .hex file are located.
When it's connected and up'n running I open and import my old tune-file from my previous project.
Reboot the ECU - Done!
Re: Here is how I transfer tune between versions
Well, that should totally work as intended. Those steps should produce proper results.
Just an odd way since rusEFI console has "full chip erase" button and "manual DFU update" and well, even "automatic firmware update" and TS has automatic .ini retrieval mechanism. Well, it's just that it's broken in non-beta version thus TS Beta is currently recommended at https://github.com/rusefi/rusefi/wiki/HOWTO-create-tunerstudio-project#download-and-install
But again - your procedure with explicit manual steps should totally work and it's best if rusEFI console is broken for any reason.
