Hello guys,
I have 1987 JDM Toyota Hilux with 3Y-C engine (with EGR). Runs with 36" superswamper tires. So i need more power. And started my project at this point =)
When microrusefi started to be sold, I bought 2 kits to use on k24. But i didn't have much time. Unfortunately I work on microrusefi right now.
I just started the project with problems =). So my computer didn't recognize the board. I checked forum and find 1 solution. i tried and still not working. When i plug the USB cable generally nothing happened, few times pc give this error "unknown device". i tried many of drivers. So i am working on it.
Have a nice day
K24 Swap Project (microrusefi)
- K24 Hilux Project
- Github Username: TemPesT
87 Hilux JDM
06 Grand Cherokee 3.0 CRD
12 WR125-R
12 WR125-R
Re: K24 Swap Project (microrusefi)
What version of Windows?
Please provide a screenshot of device manager. Drivers would only help if your hardware is working. You say old kit so it sounds like fragile microUSB port, sometimes you need a different cable to have microUSB working reliably.
- K24 Hilux Project
Thank you for your interest and helping. I tried different 3 cable. 1 cable doesn't work but others connectivity fine, i checked with multimeter.
this is win10 64bit, computer MSI GS63VR, rusefi board R04.82L.
JP1 and D42 is empty.
87 Hilux JDM
12 WR125-R
12 WR125-R
So problem solved with new cable?
if not please paste device manager screen shot.
if there is nothing on device manager there is nothing we can really do - I do not recall any typical problem, as long as you have firmware (do you have firmware?) it should just work
if it does not have firmware are you trying to enter DFU mode using the hardware BOOT button?
- K24 Hilux Project
Problem not solved with new cable. So i am gonna try different PC. com port looks empty. Rusefi connected to COM6.AndreyB wrote: ↑Sat Sep 17, 2022 8:32 pmSo problem solved with new cable?
i am going to try 2 thing right now.
1- different PC
2- Other microrusefi board
87 Hilux JDM
12 WR125-R
12 WR125-R
- K24 Hilux Project
com6 doesn't seen. COM6 working, i tried arduino, it is fine.
87 Hilux JDM
12 WR125-R
12 WR125-R
Does MRE blink at all? Do you know if it has firmware?
- K24 Hilux Project
doesn't blink anythink.
if i have to load firmware i can. my idea was it came with firmware
87 Hilux JDM
12 WR125-R
12 WR125-R
Manual DFU mode is when you hold "Program" button while powering your rusEFI in order to switch it into DFU mode. This mode is used to program brand new stm32 chips which do not have a running version of rusEFI firmware.
https://wiki.rusefi.com/HOWTO/HOWTO-DFU/
microRusEFI documentation has links to relevant bundle
- K24 Hilux Project
driver done right now
87 Hilux JDM
12 WR125-R
12 WR125-R
- K24 Hilux Project
orange led light
blue led blink
87 Hilux JDM
12 WR125-R
12 WR125-R
