General Purpose PWM Load axis
ELMEPRO
Post by ELMEPRO »
Hello, im using CWA400 pump and pwm based fan control, i have some questions, there is no explanation how LOAD AXIS work??
Sou load axis what i understood from 0 to 100 right?
if i use Engine Coolant axis, how it knows at what temperature its 100 (load) ?
Im playing with load axis and cant get it to work normally, from 20 degree to 100 degree table moves only from aprox. 85 to 95 (load), sou its weary narrow.
Also, it would be nice to have pwm fan option in fan section
Re: General Purpose PWM Load axis
It just says "load". You can use whatever values you want that are appropriate for the channel you've selected.
See my CWA400 control with GPPWM here: https://rusefi.com/online/view.php?msq=969&dialog=gppwm3
