Haltech CAN bus Communication don't work.
hugovw1976
Github Username: hugovw1976
Post by hugovw1976 »
Hi , I have a custom board base on Proteus running latest firmware ("rusEFI 2022.03.16.proteus_f4.1421086421"), I have a AIM MXL Pista dash and test Haltech dash and don't work, I also check with VAG and AIM and this work fine (can communication it's fine in board).
I check in Console and Haltech don't send any messages, I want the Haltech protocol because have more information, It's posible to check this error.
Thanks.
https://github.com/mck1117/proteus/issues/111
hugovw1976
Re: Haltech CAN bus Communication don't work.
I check code apparently Haltech dash is not initiate:
void canDashboardBMW(CanCycle cycle);
void canDashboardFiat(CanCycle cycle);
void canMazdaRX8(CanCycle cycle);
void canDashboardW202(CanCycle cycle);
void canDashboardBMWE90(CanCycle cycle);
void canDashboardVagMqb(CanCycle cycle);
void canDashboardNissanVQ(CanCycle cycle);
void canDashboardGenesisCoupe(CanCycle cycle);
void canDashboardAim(CanCycle cycle);
void updateDash(CanCycle cycle) {
	// Transmit dash data, if enabled
	switch (engineConfiguration->canNbcType) {
	case CAN_BUS_NBC_BMW:
		canDashboardBMW(cycle);
		break;
	case CAN_BUS_NBC_FIAT:
		canDashboardFiat(cycle);
		break;
	case CAN_BUS_NBC_VAG:
		canDashboardVAG(cycle);
		break;
	case CAN_BUS_MAZDA_RX8:
		canMazdaRX8(cycle);
		break;
	case CAN_BUS_W202_C180:
		canDashboardW202(cycle);
		break;
	case CAN_BUS_BMW_E90:
		canDashboardBMWE90(cycle);
		break;
	case CAN_BUS_MQB:
		canDashboardVagMqb(cycle);
		break;
	case CAN_BUS_NISSAN_VQ:
		canDashboardNissanVQ(cycle);
		break;
	case CAN_BUS_GENESIS_COUPE:
		canDashboardGenesisCoupe(cycle);
		break;
	case CAN_AIM_DASH:
		canDashboardAim(cycle);
	default:
		break;
Nice just made this better https://github.com/rusefi/rusefi/commit/f490b499971f19e01e9f2dbe165309e1bc862d36 would be about 20 minutes to build snapshot
but that also shows that this code is totally untested and unproven :(
hugovw1976
AndreyB wrote:Nice just made this better https://github.com/rusefi/rusefi/commit/f490b499971f19e01e9f2dbe165309e1bc862d36 would be about 20 minutes to build snapshot
Thanks Image
Enviado desde mi SM-G988U1 mediante Tapatalk
hugovw1976
Wed Mar 23, 2022 2:54 pm
I compile firmware with the new lines on can_dash.cpp, and can confirm Haltech can communication works now, just need to check if all the channel are correct but I don't have time until the weekend.
Thanks.
hugovw1976
Check all output channels and looks good, just the Intake temperature and fuel level is not declared in can_dash.cpp
	/* 0x3E0 = 5Hz rate */
			CanTxMessage msg(0x3E0, 8);
			/* Coolant temperature in K y = x/10 */
			tmp = ((Sensor::getOrZero(SensorType::Clt) + 273.15) * 10);
			msg[0] = (tmp >> 8);
			msg[1] = (tmp & 0x00ff);
			/* Air Temperature */
			msg[2] = 0x00;
			msg[3] = 0x00;
			/* Fuel Temperature */
			msg[4] = 0x00;
			msg[5] = 0x00;
			/* Oil Temperature */
			msg[6] = 0x00;
			msg[7] = 0x00;
Air temperature is the intake air temperature. must be :
			tmp = ((Sensor::getOrZero(SensorType::Iat) + 273.15) * 10);
			msg[2] = (tmp >> 8);
			msg[3] = (tmp & 0x00ff);
			msg[4] = 0x00;
			msg[5] = 0x00;
			msg[6] = 0x00;
			msg[7] = 0x00;
Fuel Level in code:
/* 0x3E2 = 5Hz rate */
			CanTxMessage msg(0x3E2, 2);
			/* Fuel Level in Liters */
			msg[0] = 0x00;
			msg[1] = 0x00;
must be:
			tmp = (Sensor::getOrZero(SensorType::FuelLevel)* 10);
Intake Air Temperature tested and working, Fuel Level not nested.
Please-please-please invest an hour of your time to properly fork https://github.com/rusefi/rusefi and push changed into your fork?
Reminder that worst case scenario you can edit files via the browser or upload files into your fork of https://github.com/rusefi/rusefi
You fix is valuable but please make it move valuable by going the proper GH route to reduce my efforts to accept your fix.
hugovw1976
AndreyB wrote:Please-please-please invest an hour of your time to properly fork https://github.com/rusefi/rusefi and push changed into your fork?
Sorry I'm very new on this, is any guide to made fork.
hugovw1976 wrote:
Wed Mar 30, 2022 5:15 pm
Please go over https://docs.github.com/en/get-started/quickstart/fork-a-repo
We are talking about one click in the right-top corner of https://github.com/rusefi/rusefi once you have a github account.
Also forum is not a chatting platform.
Slack is the chatting platform we should be using for chatting see https://rusefi.com/forum/viewtopic.php?f=13&t=1198
