Proteus connector cutout DXF
ayard
Post by ayard »
Hi,
I'm looking to install a Proteus in a metal enclosure. Are there any DXF type drawings available for the connector cut-outs? I plan to use my CNC router to cut-out the front panel. Either DXF drawings of just the AmpSeal connector cut-outs, or drawings of the whole panel will work fine for me.
I tried to find some connector cut-out drawings on the TE website, but the best I could find is a DXF of the connector itself. If I get stuck, I could work out the cut-out by drawing the cut-out on another layer and using the connector layer as a reference.
Thanks.
Al
Re: Proteus connector cutout DXF
ayard
Post by ayard »
Thanks Andrey .... once I figured out how to covert the .dwg to a .dxf (I don't have AutoCAD), and then how to re-scale it for mm, it worked like a charm!
Al
