First universal board in Hellen One family source code & user documentation
[info] AlphaX 2chan
AlphaX 2chan
Re: AlphaX 2chan
First time in rusEFI: solderless software controlled pull-ups on temperature sensors and tach output, software controlled switch between VR and Hall input.
Re: AlphaX 2chan
First time in rusEFI: JLCPCB-soldered WL9981TC bluetooth module. I need help with opening the PDF of that WL9981TC and figuring our how to initialize that thing https://github.com/rusefi/alphax-2chan/issues/14
Re: AlphaX 2chan
About 0.06A running with nothing but +12v power connected, about 0.02A in mcu stand-by mode.
Re: AlphaX 2chan
- alphax-4chan-reva-render.jpeg (282.98 KiB) Viewed 8256 times
Re: AlphaX 2chan
4chan is officially alive
Re: AlphaX 2chan
Quick thermal test
5 minutes of 5000 rpm with real injectors on the bench, similar 20C above ambient on both rev A and rev C
- 4chanC.jpg (101.04 KiB) Viewed 7248 times
- 4chanA.jpg (104.22 KiB) Viewed 7248 times
Re: AlphaX 2chan
Very few people would need a debugger on AlphaX or any Hellen unit but well, here are your three options (https://github.com/rusefi/rusefi/wiki/Tag-Connect-TC2030 describes all three)
most proper - order and solder FTSH-105-01-F-DV-007-K connector and v3 st-link which is cheap
proper with zero soldering, most expensive: v3 + proper tc2030 cable for v3
cheapest: v2 + ghetto tc2030 based on eBay TC2030-MCP-NL with phone jack cut off
Re: AlphaX 2chan
Re: AlphaX 2chan
4chan has embraced dual-side assembly and USB-C
- photo_2023-05-09_09-59-29.jpg (261.22 KiB) Viewed 4309 times
